Smallest footprint HT Recliners - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-13-2012, 10:12 AM - Thread Starter
Pat Sexton's Avatar
I have a small HT build (11'5 x 20) that is getting smaller (decoupling, DD, GG). My wife says seating 8 is non-negotiable, so i am trying to find two rows of four (o/oo/o) that we can squeeze by to get to the second row.
What manufacturer / model has the smallest footprint?
Pat
Pat Sexton is offline
post #2 of 10 Old 04-13-2012, 02:54 PM
BroncoSport's Avatar
The Fusion series chairs from rtheaters.com (Roman) have a couple sets that have a narrow footprint (width). I think without loosing one aisle, you aren't going to fit any of the theater recliners without loosing either the right or left aisle.
Another option is standard theater seating. You can easily get 4 of those with aisles on either side, but no foot rests.
BroncoSport is offline
post #3 of 10 Old 04-13-2012, 03:51 PM - Thread Starter
Pat Sexton's Avatar
Thanks. I think the jive model is the smallest he has. If i do two loveseat style in the front (/oo/oo/) i think it will be about 104". That should leave enogh room to squeeze by to get to the second row.
post #4 of 10 Old 04-14-2012, 07:08 AM
TheaterSeatStore's Avatar
Pat,
There are several good options from the best brand names in home theater seating, such as Palliser. Do you have a certain measurement so I can really narrow some down for you? Without knowing your measurements I would first recommend the Blade or the Bullet from Palliser. Look forward to hearing the measurements
Martin
TheaterSeatStore.com
TheaterSeatStore is offline
post #5 of 10 Old 04-14-2012, 09:49 AM
KenLerch's Avatar
Liked: 29
Pat,
Also take a look at the following models:
Albany Metro: Features lighted cup holders, Try tay & Storage all with a more narrow footprint
Lane 220: basically the Berkline (who went out of business around a year ago) 45088
Depending on the space and considering you would like to do a loveseat, the Palliser Cyclone.
Please post the actual space you have for your chairs.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #6 of 10 Old 04-15-2012, 03:03 PM - Thread Starter
Pat Sexton's Avatar
Thanks for all of the options guys, I am going to start looking at specs right now. The space is 11' 5" inches now. If I remove the current drywall and decouple, DD, GG, it should end up right at 11' (132"). I am not worried about isles (just need enough space for someone to squeeze by to get to the second row, and I know the outer seats audio will be a compromise (right below surrounds)...
Thanks again for the options.
post #7 of 10 Old 04-16-2012, 05:56 AM
KenLerch's Avatar
Liked: 29
Pat,
Thanks for posting the measurements. Any of the chairs mentioned here will fit the 132" that you have including the Lane 220, Palliser Cyclone the Albany Metro and a couple of others.
Ken Lerch
StargateCinema.com
HTSeating.com
KenLerch is offline
post #8 of 10 Old 04-16-2012, 01:27 PM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
This is great info. I'm a few months away from needing chairs, but my room is on the narrow side too (~144" with wall treatments).
GWCR is offline
post #9 of 10 Old 04-16-2012, 05:12 PM
Bowman721's Avatar
Also the Row One City Lights (their version of the Berkline 45088). It's the narrowest footprint I am aware of. Significantly narrower than the Lane 220.
Randy Bowman
myHTseats.com
Bowman721 is offline
post #10 of 10 Old 07-01-2012, 04:44 AM
dsskid's Avatar
Quoted: 271 Post(s)
Liked: 258
I just picked up a gently used, 4 seat configuration of the Berkline 45088s at an unbelieveable price of $500 (originally thought they were 12006, but the tag says 45088). I could only fit 3 seats in the room, so the 4th went into my daughter's room as her tv chair.
They are comfortable as anything. I'm 5'8" 225, and they fit well, but the low backs would not be good for taller people.
449
450
chairs 003a.jpg 139k .jpg file
chairs 002a.jpg 133k .jpg file
ID:	62174   Click image for larger version
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
Reply Theater Room Items & Accessories
