Popcorn Capacity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-23-2012, 12:31 PM - Thread Starter
rhinomike's Avatar
Quoted: 34 Post(s)
Has anyone tried putting the 12 ounce packet of popcorn and oil in an 8 ounce machine? How did it do?
When I use the 8 ounce packages in my 8 ounce machine quite a bit of unpopped kernels fly out of the kettle. So I am thinking I can get 12 ounce packages to get a little more popped corn....
Thank You.
rhinomike is offline
post #2 of 4 Old 04-23-2012, 08:44 PM
brickie's Avatar
Quoted: 24 Post(s)
Liked: 26
Actually I've tried this with my 4 oz machine.Using 6-8 oz packs. Best result comes from using the packs designed for it.To combat the problem you speak of I did add 3 washers for a little weight to weight down my lid while popping. I jsut made sure they could slide up the stir shaft. Works great and has really cut down on the unpopped kernels.
brickie
AM I THE ONLY OASIS IN THE DESERT OF STUPIDITY......" SIR BRICKENBOCKER"
brickie is offline
post #3 of 4 Old 04-24-2012, 06:51 AM - Thread Starter
rhinomike's Avatar
Quoted: 34 Post(s)
I will try that. Thank u for the idea.
post #4 of 4 Old 09-08-2012, 08:40 AM
suffolk112000's Avatar
I was just sort of curious as to the experiences of other forumites had with this.
I have the Paragon 6oz popper and I frequently use 8 oz packs. It has been working great for me. No more un-popped kernels than usual. When I bought the 6 oz, my kids were both pretty small, but now they both eat quite a bit more and 6 oz is not enough for all of us, but two batches is too much.
Domino's donÂt fall all at once, they fall one at a time...
suffolk112000 is offline
Reply Theater Room Items & Accessories
