AV Furniture Recommendations Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-14-2012, 01:25 PM - Thread Starter
Anhydro's Avatar
I'm looking for a piece of quality furniture that will fit a 65" display and an approximately 8" inch high center channel speaker. I would appreciate any recommendations to websites or specific furniture pieces. I've run across Salamander but wondered if there were any other quality pieces with a traditional look. Thanks!
Anhydro is offline
post #2 of 6 Old 06-14-2012, 09:50 PM
Schloob1's Avatar
Here's a site that has been featured here before,exactly what you're looking for.
http://www.standoutdesigns.com/
Schloob1 is offline
post #3 of 6 Old 06-15-2012, 02:20 PM - Thread Starter
Anhydro's Avatar
Excellent... I had seen an ad for this but couldn't recall the name of the company. Thanks!
Anhydro is offline
post #4 of 6 Old 06-15-2012, 05:09 PM
Schloob1's Avatar
Anytime, personally would LOVE to get something from these guys but they are nowhere near my budget. But to those that can get it their furniture looks to be really good.
Schloob1 is offline
post #5 of 6 Old 07-23-2012, 07:02 PM
tripmaster's Avatar
I am in need of a new AV furniture system; had the Salamander 3-across system. Nice, but bulkier than I want. Problem is I have a 16.9" deep Denon 4306 receiver which seems to be too deep for most systems. Want something minimal like this but deep enough!
http://www.cb2.com/grid-media-console.-66wx18dx22h/s224220
Any ideas?
tripmaster is offline
post #6 of 6 Old 07-25-2012, 11:31 AM - Thread Starter
Anhydro's Avatar
Any ideas?
You might check out Nebraska Furniture Mart. You will need to go through a menu starting with Furniture, then Living Room, then Entertainment Furniture, then TV stands. I'm not sure what you consider bulky... but there are a lot choices here.
Anhydro is offline
Reply Theater Room Items & Accessories
