Help me identify this carpet... - AVS Forum | Home Theater Discussions And Reviews
Old 07-14-2012, 03:09 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
Recently purchased a new home where the basement was already finished years ago with the carpet below. I am finishing off the old work room into a media room and would love to use this carpet again. Does anyone know what brand or manufacturer it might be from.
700
There is a small roll of it left with the following barcode if it helps.
450
Thanks in advance.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
Old 07-15-2012, 12:10 PM
KenLerch's Avatar
This does not look like a familiar carpet in the "home theater" realm per se. I would take a photo or the actual tag to the largest local carpet warehouse and see if they can identify it. They deal with a wider range of manufacturers than us HT guys and would be able to help you better since this really isn't a dedicated "home theater" themed carpet. Good luck. I think you should be able to track it down without much problem given the info on the tag.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
Old 07-16-2012, 08:05 AM
dcg58's Avatar
You could also get an app to read the barcode on your phone and see what info it reveals. I did that to check something and you would be surprised at the results.
I was able to scan the code after posting this reply and it only read the label as J8719.
I Googled several of the label numbers and the manufacturer may be MOHAWK. I didn't have time to search through all their selections to find it though.
My Vintage style Home Theatre Build thread:
http://www.avsforum.com/t/1400234/vintage-look-diy-theatre-build
dcg58 is offline
Old 07-16-2012, 11:42 AM
KenLerch's Avatar
Here is Mohawk's site, which has a "dealer locator" page at the top:
http://www.mohawkflooring.com/carpeting/
Ken Lerch
StargateCinema.com
HTSeating.com
KenLerch is offline
Old 07-16-2012, 12:13 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
Thanks guys. I tried a couple bar code apps but they came up with nothing. I also took a piece of it to a local carpet place and they weren't very helpful. I was going to try another but thought I would post here too.
blipszyc is offline
