Berkline Accessory Mount - Universal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2012, 10:19 AM - Thread Starter
AaronHal's Avatar
Sorry if this is a dumb question, I wasn't able to search out an answer. I recently picked up a Berkline Power Recliner for cheap (not sure the model; doesn't have papers or markings I can find), and it's got these table/accessory mounts on the arms just past the cup holders. On other chairs (Palliser in particular), there seem to be several accessories available for this mount.
Does anyone know if these mounts are universal, or if they are specific to each manufacturer? The mount is a metal disc with a hole in the center for a pole to be slotted into.
I'd like to order an iPad mount from somewhere, something like this http://www.stargatecinema.com/Palliser-iPad-Tablet-Holder-pr-93051.html, but I want to be sure first.
AaronHal is offline
post #2 of 4 Old 07-16-2012, 11:40 AM
KenLerch's Avatar
AaronHal,
Yes, the Palliser iPad Holder should fit your Berkline model chair. Palliser uses the same type of system on their tray tables and iPad holders. The metal cylinders used by each manufacturer are very similar and usually the same diameter. If you can measure the inside diameter of the small metal cylinder that gets pressed down when you insert an accessory we can verify for you.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #3 of 4 Old 05-08-2015, 12:16 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Does anyone know where you can get the mount that goes into the arm... I would like to adapt it to my Coaster Palladium seats.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #4 of 4 Old 05-10-2015, 03:22 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Disregard i found the one that goes in the iPad chair for $16 on Amazon.... Just need to mod the bottom for the cup holder.
ellisr63 is offline
Reply Theater Room Items & Accessories
