HDMI & TOSLINK SWITCHER - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2012, 10:58 AM - Thread Starter
djqwik's Avatar
Can someone recommend a HIGH SPEED HDMI AND TOSLINK switcher that has a remote? I need something to put in an AV Cabinet. I'm looking for something with at least 4 or 5 ports and not too expensive.. I saw ONE but it was VERTICAL and wouldnt work in the cabinet. Most of the other ones I see are HDMI only. I currently own one but it is older and doesnt seem to support HIGH SPEED HDMI so it is sometimes locking up my my devices..
Thanks....
Dave
djqwik is offline
post #2 of 5 Old 07-22-2012, 06:42 PM - Thread Starter
djqwik's Avatar
anyone ????
djqwik is offline
post #3 of 5 Old 07-23-2012, 09:03 PM
_Hawk3y3_'s Avatar
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=7974&seq=1&format=2
Not sure if this would meet your needs or not. Are you looking for a switcher that accepts toslink inputs or do you only need the single toslink output?
_Hawk3y3_ is offline
post #4 of 5 Old 07-24-2012, 06:18 AM - Thread Starter
djqwik's Avatar
I need one that has 4 or 5 HDMI and 4 or 5 TOSLINK INPUTS and then 1 HDMI and TOSLINK OUTPUT. This is for use with older equipment that needs HDMI and TOSLINK. I have one now but it doesnt support HIGH SPEED or 3D. I did find one for under $100 but it doesnt support 3D or high speed. I did find one for around $275 but I dont know anything about it and its a little more then I want to spend.... http://www.octavainc.com/HDMI%20switch%204port_toslink.htm
Any ideas?? MONOPRICE said they do not carry anything like this...
djqwik is offline
post #5 of 5 Old 07-24-2012, 04:45 PM
_Hawk3y3_'s Avatar
Did some more searching, didn't find a whole lot out there, and nothing under $200. Have you thought about saving up a bit more money and simply purchasing a new receiver?
Reply Theater Room Items & Accessories
