Change Led Lighting On Theater Seats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-25-2012, 03:30 AM - Thread Starter
khadafi's Avatar
i already ordered my seats, the palliser bullet. they are coming in next week. http://www.theaterseatstore.com/palliser-bullet-power?sc=9&category=149. has anyone tried changing the led lights to the cup holders and the base rails. i would like to change them from blue to green. how hard would this be and is it even possible.
khadafi is offline
post #2 of 2 Old 08-01-2012, 10:33 AM
dunnmike's Avatar
I have never done so on the theater seating but I do have some experience with led lights. If done properly shouldn't be very hard. They have led light strips that you can order online that all you have to do is cut to length and solder the 2 wires *properly polarized of course* on to. I have done is added led lighting to some friends motorcycles and it was a snap. I imagine that the strip lighting is what is installed from the factory anyways. I do not know what the voltage requirements are for the theater seating lights and what size the transformers are so if you where to do this project, I would look at the specifications of the power transformer and make sure that you do not have to add resistors to the + side of the new strip, OR find a strip that matches the output voltage of the power supply. I have found the light strips on amazon order to length. I hope this helps.
edit:
i found this for you on a quick search. I hope that nobody gets mad about a posted link. I have no idea the quality of this particular set just showing it as an example of the possibility.
http://www.amazon.com/Ledwholesalers-Changing-LED-Strip-Controller/dp/B0040FJ27S/ref=sr_1_1?ie=UTF8&qid=1343842577&sr=8-1&keywords=led+strip
dunnmike is offline
Reply Theater Room Items & Accessories
