TV Riser? - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2012, 07:48 PM - Thread Starter
repete66211's Avatar
Quoted: 130 Post(s)
Liked: 287
I'm itching to add an amp and the Oppo 93, but I'm out of room on the TV stand. Ideally I'd like to move the center channel to the top shelf and have the TV over it on a riser of some sort. I've run a search on both AVS and Google but I'm not having much luck. There are a couple of products (i.e. Wood Technology) but they've all been too small. Obviously I could DIY it, but I don't have the tools or a shop. It's probably a long shot, but anyone have a suggestion?
My speaker is 23" wide x 8" high x 10" deep. The TV base is 24.5"x12.5" Here's some context:
repete66211 is offline
Old 07-26-2012, 10:24 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
If you have a simple drill and a screwdriver you can get an Ikea door (or maybe something a little longer) http://www.ikea.com/us/en/catalog/products/00103480/ and a set of the Ikea Capita legs http://www.ikea.com/us/en/catalog/products/20049538/. It's been discussed here, but it's not always easy to find.
Sonyad is offline
Old 07-26-2012, 11:21 PM - Thread Starter
Quoted: 130 Post(s)
Liked: 287
Brilliant. Thanks for the info. I've heard we may be getting an IKEA soon, so I might have to check this out.
Old 07-27-2012, 02:34 PM
WagBoss's Avatar
I'm sure different cabinet makers or types of woodshops could do it for relatively cheap. I got my TV riser built and painted for free, but I knew the guy :P
WagBoss is offline
Old 07-27-2012, 07:05 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
You should just order the legs and shop for the board locally.
Sonyad is offline
