BEST FLAT SCREEN TELEVISION MOUNT ADVICE NEEDED!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2012, 09:45 AM - Thread Starter
tazbom's Avatar
I am purchasing a 65 inch Samsung UN65ES8000F flat screen television. It is going to be recessed into a wood cabinet a few inches. I need a television mount that will pull out for easy access to wiring, but I don't really need to angle the tv as it will be just above eye level with most viewing positions straight on. Can anyone give me the best mount for this purpose? I am most likely going to purchase the Sanus VLF320.
http://www.sanus.com/us/en/products/visionmount/full-motion-mount/VLF320
Any recommendations are much appreciated!
tazbom is offline
post #2 of 4 Old 10-11-2012, 04:55 PM - Thread Starter
tazbom's Avatar
Anyone?
tazbom is offline
post #3 of 4 Old 10-14-2012, 12:24 PM
dcg58's Avatar
I have this one from monoprice for my 80" Sharp and it works great.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=6517&seq=1&format=2
For less than 1/3 the price you can save some $$.
My Vintage style Home Theatre Build thread:
http://www.avsforum.com/t/1400234/vintage-look-diy-theatre-build
dcg58 is offline
post #4 of 4 Old 10-19-2012, 04:10 PM
smudge981's Avatar
Quoted: 51 Post(s)
Liked: 207
+1
You can't beat Monoprice for the price. I suggest you simply peruse the site and choose the one that best suits your need. I did a wall mount with mine and you can literally hang from it. Solid construction.
"I am NOT suffering from insanity... I happen to be enjoying myself!"
smudge981 is offline
Reply Theater Room Items & Accessories
