Kettle Corn in popper - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-04-2012, 11:46 AM - Thread Starter
heffneil's Avatar
Has anyone made Kettle corn in their popcorn popper? I have the pre-measured stuff and I tried it with some sugar and it didn't come out very good. Looks like the sugar burned. The other chemicals that has like the butter flavor and salt I don't think goes well with it. Anyway some input would be appreciated!
Neil
heffneil is offline
post #2 of 7 Old 11-04-2012, 01:53 PM
pcdoctor's Avatar
This is what I use instead of kettle corn. It tastes just like cracker jack. From what I understand, I think Gold Medal says you should have a special kettle for popping kettle corn.
pcdoctor is offline
post #3 of 7 Old 11-04-2012, 02:10 PM - Thread Starter
heffneil's Avatar
Can you use this is a popcorn machine?
heffneil is offline
post #4 of 7 Old 11-04-2012, 03:00 PM
pcdoctor's Avatar
Yes, I use the Gold Medal "Glaze Pop" in my Star popper.
It's soooooo good!
The package says not to use salt but my Gold Medal popcorn has the salt and popcorn in the same packet.
Even using salt, it tastes great
From Concession Stands' website
"Glaze Pop is a light popcorn frosting and will not offer the full kernel coverage of traditional candy coated popcorn that is made with specialized equipment. Glaze Pop offers an easier, more economical alternative to using expensive mixing equipment and is the only product available that is custom formulated for use in a regular popcorn machine."
http://www.concessionstands.com/CARAMEL-GLAZE-POP-48-4-OZ-
http://www.gmpopcorn.com/products/product-description.cfm?pid=
http://www.popcornpopper.com/77401.html
"Make Caramel Glazed Popcorn in your Whirley Pop! Fresh, warm Caramel Glazed Popcorn is a special treat that in the past has been a multi-step recipe that could take over one hour for each batch."
Directions:
Use the regular amount of popping corn and oil. Do not use salt. Use a measure of Glaze Pop that is equal to half the quantity of popping corn. For example, with 1/2 cup of popping corn you will need 1/4 cup of Glaze Pop.
Glaze Pop cooks directly in the pan - put the oil in the pan, allow to melt and get hot, then add your popping corn. Slowly add the measure of Glaze Pop.
Let pop and dump corn promptly. Do not wait until every last kernel is popped. Make sure all corn is out of the pan. This prevents burning.
Repeat for additional batches, always making sure the oil is melted before adding corn and Glaze Pop.
This is the popcorn that I use. The salt is mixed in with the popcorn in this pack.
pcdoctor is offline
post #5 of 7 Old 11-23-2012, 12:46 PM
vail3100's Avatar
Thanks for posting the pictures. It was very easy to find.
vail3100 is offline
post #6 of 7 Old 11-26-2012, 03:02 PM
nebrunner's Avatar
Quoted: 52 Post(s)
Liked: 53
I made this in my paragon popper and it was a pain to clean up after.
nebrunner is offline
post #7 of 7 Old 11-26-2012, 03:56 PM
pcdoctor's Avatar
I don't have the glaze pop every time I eat popcorn but I make sure I clean the kettle before it cools.
pcdoctor is offline
Reply Theater Room Items & Accessories
