MoviePoster - Virtual movie poster display software. - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
post #451 of 2417 Old 08-09-2013, 01:53 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
I agree with staying away from a plasma for this application.
As far as the resolution goes I guess it might depend on how close you actually are when you look at it. I walk within a couple feet of mine all the time and would appreciate the higher resolution. I notice it more on the text and logos than the actual poster though.
meyer64 is offline
post #452 of 2417 Old 08-09-2013, 07:09 PM
loma's Avatar
Quoted: 21 Post(s)
Originally Posted by meyer64 View Post
sounds kinda weird. The poster, metadata, and trailer info is actually sent to the display method as one object. so if its showing a new trailer, it should have gotten the new poster data as well, unless it was invalid for whatever reason. are there particular posters that just never show, or do they work sometimes and not others? can you send me a log file when this happens? there might be some error messages in it that can help.
Here is a log: https://dl.dropboxusercontent.com/u/19298307/log.txt
The situation did not occur when this log was taken. However in this case while the "Automatically Play Trailers" was "yes", a trailer would only play when I clicked "Show Trailer" on Remote twice. I will keep it running to see if the previous situation is repeated. In the interim, based on this log, can anything be determined?
It is also now freezing if it does eventually play a poster.
Really weird..now another issue I can hear sound from a trailer which does show but a poster is visible.
loma is offline
post #453 of 2417 Old 08-14-2013, 09:03 AM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 232
I can get everything to work if I run XBMC 11.0 and movieposter on the same machine, but once I configure movie poster to connect to my main HTPC which is running XBMC 12 it will not show what is playing, only coming soon. I was wondering if you have resolved this problem with the current XBMC stable?
All gone for now---->The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #454 of 2417 Old 08-14-2013, 09:14 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Yes it should work just fine with the latest xbmc stable release. Double check that you have both options turned on in xbmc under the remote control options for allowing programs to control xbmc
meyer64 is offline
post #455 of 2417 Old 08-14-2013, 09:34 AM
loma's Avatar
Quoted: 21 Post(s)
meyer: Any ideas?
loma is offline
post #456 of 2417 Old 08-14-2013, 09:37 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
The only oddity I noticed is that your running from a network share and had a few times that permission was denied to change or write a file. Might be a good idea to double check your permissions
meyer64 is offline
post #457 of 2417 Old 08-14-2013, 09:47 AM
malelan's Avatar
anyone tried using this with xbmc 13.0 alpha? was there significant changes in the json-rpc between 12 and 13? (i thought just more commands added)
having trouble here and getting the dreaded "Error updating media information from XBMC - Object reference not set to an instance of an object."
additionally i have something else connected to my json-rpc socket (that i use to control xbmc) could this be causing issues?
Jon
malelan is offline
post #458 of 2417 Old 08-14-2013, 09:54 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
It shouldn't matter if you have something else using the json interface. I use the ipad remote app and movieposter on the same xbmc instance with no issues.
I have not done any testing on the xbmc 13 builds yet, so it's completely unsupported at the moment, but I'll make a point to test it.
meyer64 is offline
post #459 of 2417 Old 08-14-2013, 10:13 AM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 232
Which folders on which computer for the permissions? Cause I can connect and change all files on my nas from any computer.
BCRSS is offline
post #460 of 2417 Old 08-14-2013, 10:47 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Sorry, that response was meant for loma.
To answer your question, MoviePoster should work just fine with the latest xbmc stable release. Im running 12.2 myself.
Double check your ip and port settings and that you have both options turned on in xbmc under the remote control options for allowing programs to control xbmc.
BCRSS likes this.
meyer64 is offline
post #461 of 2417 Old 08-14-2013, 12:21 PM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 232
well apparently xbmc username is case sensitive. All is working good and will donate now that I have confirmed the usability of this. Thanks
BCRSS is offline
post #462 of 2417 Old 08-14-2013, 01:34 PM
malelan's Avatar
i'll downgrade one of my machines and give it a shot, dont bother testing 13, i'll let you know if this is a version compat issue or not, so you'll be prepared!
malelan is offline
post #463 of 2417 Old 08-14-2013, 06:06 PM
loma's Avatar
Quoted: 21 Post(s)
Thanks meyer. Which permissions should I check? (Windows 8)
It all worked a while ago and I have changed nothing.
Have since reinstalled MoviePoster. However trailers do now show but not with the correct poster. In addition while my custom poster is visible, a trailer plays.
I have MP set up on another computer (Windows 7) and it works OK.
loma is offline
post #464 of 2417 Old 08-15-2013, 05:52 AM
malelan's Avatar
just wanted to update that i got this working from another computer on one of my other xbmc 13 machines, so this definitely works with xbmc 13, must have some other problem with what i was trying yesterday, i'll see if i can figure it out.
malelan is offline
post #465 of 2417 Old 08-15-2013, 03:24 PM
linkseo's Avatar
Liked: 25
im loving this software. Thanks for making it. Got my 32" lcd mounted and set up at the entrance to my theater. Right behind the velvet rope. great for people waiting LOL.
almost feel like removing my movie posters. dont interest me anymore wink.gif
linkseo is offline
post #466 of 2417 Old 08-15-2013, 03:49 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
meyer64 is offline
post #467 of 2417 Old 08-19-2013, 02:09 AM
happyface76's Avatar
I've installed the latest version of MoviePoster (1.0.1.5) and the latest XBMC (12.2)
The problem is that the now playing does not show any information?
I've tried it with both the normal DB of xbmc and an MySQL db (my default)
I've checked and verified that XBMC is properly configured. The website is running and both options onder Remote control are turned on. Usename and password are both filled in.
I've also tested it with an remote XBMC maching (running XBMCbuntu), same result.
Logfile:
19/08/2013 11:05:00 - Init
19/08/2013 11:05:00 - Found DirectSound Device: Primary Sound Driver
19/08/2013 11:05:00 - Found DirectSound Device: Speakers (High Definition Audio Device)
19/08/2013 11:05:00 - Found DirectSound Device: Digital Audio (S/PDIF) (High Definition Audio Device)
19/08/2013 11:05:01 - Updating UI started for
19/08/2013 11:05:01 - Updating UI Finished
19/08/2013 11:05:16 - Remote control webserver is running on port 8082.
19/08/2013 11:05:16 - Getting New Poster List
19/08/2013 11:05:16 - Pause Off
19/08/2013 11:05:16 - Updating UI started for
19/08/2013 11:05:16 - Updating UI Finished
19/08/2013 11:05:16 - Now Playing movie count: 20
19/08/2013 11:05:17 - Pause Off
19/08/2013 11:05:17 - Updating UI started for
19/08/2013 11:05:17 - Updating UI Finished
19/08/2013 11:05:20 - Show Next
19/08/2013 11:05:20 - Cached Posters List Ready
19/08/2013 11:05:20 - Found Local Trailer for tt0301357
19/08/2013 11:05:20 - themoviedb.org is unavailable or new poster not yet downloaded, loading random from cache.
19/08/2013 11:05:20 - Nothing Is Playing.....Updating From Cache
19/08/2013 11:05:20 - Updating UI started for Goodbye Lenin!
19/08/2013 11:05:20 - Updating UI Finished
19/08/2013 11:05:20 - Pause Off
19/08/2013 11:05:32 - Popular movie count: 20
19/08/2013 11:05:40 - Error updating media information from XBMC - Object reference not set to an instance of an object.
19/08/2013 11:05:47 - Upcoming movie count: 20
19/08/2013 11:06:03 - Top Rated movie count: 20
19/08/2013 11:06:18 - New Posters List Ready
19/08/2013 11:06:49 - XBMC Version is: 12.2
19/08/2013 11:06:56 - Error updating media information from XBMC - Object reference not set to an instance of an object.
With XBMC 11 i have no problems, but all my XBMC machines are running XBMC12.2!
Does anyone have an idea?
happyface76 is offline
post #468 of 2417 Old 08-19-2013, 02:34 AM
Updating to MoviePoster 1.0.1.6 seems to have solve this issue.
post #469 of 2417 Old 08-28-2013, 08:40 AM
loma's Avatar
Quoted: 21 Post(s)
Still having problems playing trailers as previously reported.
Is another release imminent?
Any progress re MediaBrowser 3?
I think it was mentioned re the possibility with Raspberry Pi. Is this in the future?
loma is offline
post #470 of 2417 Old 08-28-2013, 09:01 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
I haven't been able to replicate your trailer issue. And since the issue did not occur in the log you sent me, I haven't been able to determine what causes the problem. But, as I said before, check the permissions on the network share that your running MoviePoster from. There are errors in the log that suggest that the program was unable to access files. Also, what trailer plays when your custom poster is shown? is it always the same? When the wrong trailer plays, is the trailer for the previous poster that was shown or just completely wrong? Logs from when the issue happens would help a lot. if you could, send me a copy of the .nfo file from one of the posters that plays the wrong trailer. You can find the .nfo in the cache folder for the movie.
The next release is VERY close to being finished, but I don't expect to have time to finish it up for a couple weeks. I'm trying to spend time with my kids before they go back to school, so this project hasn't been real high on the priority list until I have more free time.
I've done some testing of MB3 and poked around in the API's and it does look to be possible to integrate with MoviePoster, but nothing is finished yet.
I did pick up a raspberry Pi to play with, but my time with it has been pretty minimal so far. Don't expect MoviePoster to run on the Pi anytime soon though as it will require a complete rewrite of most of the code. MoviePoster does support integrating with XBMC on the Pi though.
meyer64 is offline
post #471 of 2417 Old 08-28-2013, 08:16 PM
loma's Avatar
Quoted: 21 Post(s)
Thanks meyer64. Here is a log which hopefully has some indication of what's going on. I am continuing to run and log but thought I would provide this in the interim. Will provide info shortly on the other items mentioned.
https://dl.dropboxusercontent.com/u/19298307/logfile.log
loma is offline
post #472 of 2417 Old 08-28-2013, 08:40 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Out of curiosity, whats your interval timeout set to? Its pretty likely that you could run into issues if your interval timeout is too short compared to the autoplay trailer timeout.
meyer64 is offline
post #473 of 2417 Old 08-29-2013, 06:08 AM
dukedallas2005's Avatar
Just wanted to thank you Meyer64 again for this awesome app! People that come to my Theater are so amazed by it. And the posters looks almost as good as the hardcopy posters on my 46inch LCD. I just have it triggered to turn on with a wall switch and its fine, my HTPC is just running the software in the background. Thanks again man!
dukedallas2005 is offline
post #474 of 2417 Old 08-29-2013, 11:43 AM
loma's Avatar
Quoted: 21 Post(s)
Thanks. What would be a good setting? I had it set to 10. Changed to 20 but no trailers played. Is there a setting for the player that could be affected?
Still logging to see if anything shows up.
loma is offline
post #475 of 2417 Old 08-29-2013, 12:15 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
If i remember right, the auto play trailer timeout is set to 10 and the poster interval default is 30. these are good values, but you just need to make sure that the autoplay timeout is a fair amount less than the poster interval.
meyer64 is offline
post #476 of 2417 Old 08-29-2013, 01:16 PM
loma's Avatar
Quoted: 21 Post(s)
Readjusted the settings and have been running for the past hour. Looks like that was the problem. Will continue to run to ensure all's well. Thanks.
loma is offline
post #477 of 2417 Old 08-29-2013, 02:01 PM
eecyclone's Avatar
Do LCD's normally automatically turn on when connected to power? Or did you have to do something special to get it to turn on with the wall switch?
eecyclone is offline
post #478 of 2417 Old 08-29-2013, 10:48 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Awesome!!! I just wish it would run on OpenElec/XBMC so I could run it off a USB stick and a NUC.
ellisr63 is offline
post #479 of 2417 Old 08-30-2013, 08:53 AM
I do not know but the one I bought does, i myself was pretty surprised it did it. I just left it on and plugged it into a switch connect socket and it worked, very convienent.
post #480 of 2417 Old 09-02-2013, 06:02 PM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 232
Just made a donation and here are few pictures of the finished poster.
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
BCRSS is offline
Reply Theater Room Items & Accessories
