MoviePoster - Virtual movie poster display software. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
post #31 of 2417 Old 12-02-2012, 03:18 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
1. By default, the web remote is running on port 8082, so you need to specify that in your url. http://127.0.0.1:8082/remote.html would be the correct address. if you go in to the settings and change the default remote port to 80 you shouldnt need to specify it in the url, but make sure that you dont have anything else using port 80 (such as the xbmc webserver) or it will cause issues.
2. make sure that all the xbmc connection settings are correct. If your password is blank, see if it helps to specify a password. Also , if you could turn on logging and send me a snippet of the log when this happens, I can probably give you a bit more advice as to whats going wrong. I haven't tested anything on Frodo yet, so youre in uncharted waters there. Im not sure what changes there are to the JSON RPC API, but its possibly that could cause some problems too. I've done all my testing against XBMC v11. Make sure that you can ping your xbmc box from another pc too. I know its sounds weird, but the Windows 7 firewall can block ping requests. I discovered this when one of my systems wouldn't connect. I think there is a note about this in the ReadMe.
3. As far as the trailers go, make sure that the paths for both mplayer.exe and youtube-dl.exe are correct under the "mPlayer Options" tab in the settings window. my guess is one of those paths is wrong. I cant count the number of times that ive gone to test on a new machine and forgot to change those settings. Again, it would help to turn on logging and see if there is any information in there. if you see anything about a file not found exception, that because it cant find mplayer or youtube-dl. One last note... there isnt much along the lines of error checking to make sure the trailer links are valid. I have had it happen where the link provided by themoviedb is either dead or is in an invalid format, in either case there is nothing to stream, so you'lll just see the black box like your experiencing in that case too. I'll look into packaging the youtube-dl and mPlayer executables with the application in future releases.
meyer64 is offline
post #32 of 2417 Old 12-02-2012, 03:50 PM
fallenangel1's Avatar
Sorry I mistyped it in my previous post, I have been attempting to connect on port 8082 with no luck.
2. make sure that all the xbmc connection settings are correct. If your password is blank, see if it helps to specify a password. Also , if you could turn on logging and send me a snippet of the log when this happens, I can probably give you a bit more advice as to whats going wrong. I haven't tested anything on Frodo yet, so youre in uncharted waters there. Im not sure what changes there are to the JSON RPC API, but its possibly that could cause some problems too. I've done all my testing against XBMC v11. Make sure that you can ping your xbmc box from another pc too.I know its sounds weird, but the Windows 7 firewall can block ping requests. I discovered this when one of my systems wouldn't connect. I think there is a note about this in the ReadMe.
I believe I have all of the settings correct, I added a password just now and enabled logging and there's been no change. As for pinging, MoviePoster and XBMC are on the same machine and in the lower right hand corner of MoviePoster it says "connected XBMC 12.0 beta on 127.0.0.1". One other thing i noticed, it acts differently depending on what Im playing. I was streaming some trailers from XBMC and the "Coming Soon" screen popped up with the proper start and end times and the file name at the bottom of the screen but the image was the XBMC logo not the movie poster. But I am watching a movie right now and its streaming different "coming soon" posters still. Ill attach the log thats built up since I enabled it, hopefully it will shed some light on my troubles! smile.gif
logfile.rtf 64k .rtf file
If I can get the other stuff taken care of Ill look a bit harder at this, right now this is the least of my concerns.
Over all this is a great program and even if I cant use the "Now showing" function I'd be happy just creating some custom lists for a bunch of the posters I own and stream current titles to see whats new.
fallenangel1 is offline
post #33 of 2417 Old 12-02-2012, 05:39 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
I installed the Frodo Beta on my dev machine and it does indeed appear that there is an issue with MoviePoster correctly obtaining the now playing information (specifically, the movie metadata) from XBMC v12 Beta. This issue should not effect the current stable release (XBMC v11 Eden). I'll work on an update to fix it, but it will probably take a day or two until i get around to it.
The lack of a poster when playing a trailer is expected. I'm assuming you're using a plugin to stream the trailer. There currently isnt support for pulling thumbnails from media that isnt in the xbmc library, but I'll add that to my to do list too.
fallenangel1 likes this.
meyer64 is offline
post #34 of 2417 Old 12-02-2012, 05:55 PM
Well I'm glad to hear that its not just me! Now that I know what the issue is I can use it as it is until the update comes out.
As for playing trailers in XBMC, I used to use Boxee exclusively so v12 Frodo is my only experience with XBMC. I haven't downloaded any Add-on's as of yet, I just select "Trailer" under "Movie Information". Maybe its a new feature within v12? Or an add-on that was already in the install? Its not really a major problem, trailers are only on for a min or two. I just thought it may help in troubleshooting my issues. smile.gif
Thanks again for this program and all of your hard work!
post #35 of 2417 Old 12-03-2012, 09:50 AM
So I have a possible feature request, if its already in there and this is an issue related to my running XBMC v12 or its just too much work or just something you dont want to do please tell me to stfu! smile.gif
But, I have this program attached to my HTPC (like I assume most people do). The thing is I dont just watch movies on my HTPC, I watch a lot of TV shows as well .. I probably watch more TV shows than I do movies on a daily basis. Ive noticed that when I start a TV show I occasionally get the "Now Showing" screen .. Im assuming its occasional due to my issues with running v12 XBMC, that's besides the point right now though. The point is your program recognizes that I am playing something and it even places the file name at the bottom of the screen where the "tag line" typically is for a movie poster. It also pulls the sound quality and the resolution and start/finish times, but it only shows the XBMC logo in place of the poster. I was wondering if there was a way that it can search TVdb or possibly IMDB for TV show artwork. I know that XBMC seems to be able to pull artwork for my TV folders as well as programs like sickbeard. So Id guess that some web Db has an API that may be usable in a situation like this.
Also, Ive noticed that some of the taglines for the movie posters that are showing seem to be too long to display. The short ones are nice and centered and typically read just fine, but for example on the poster for The Lost Boys, it should read "Sleep all Day. Party all Night. Never grow Old. Never Die. It's Fun to be A Vampire". Now because it is so long it cuts it off to read something like .. "Sleep all Day. Party all Night. Never grow Old. Never Die. Its Fun to". I didnt know if maybe there was a way to adjust the font size if there are "X" number of characters or add a 2nd line. Or maybe easier, a way to get rid of the tag line altogether? Most are fine, but Ive noticed a good amount are either too long or some other tag lines overlap with the ratings box and other info at the bottom of the screen, possibly due to the scaling of the different image sizes. Not a major issue, but if its an easy tweak to an XML or I could just remove a paragraph from an XML and do away with it and save you the trouble, that would work as well.
I know we were working on the "Now Showing" issues I have encountered with XBMC v12 and we sorta glossed over my issue with opening the web/remote page. I didn't know if you may have any other suggestions as to what I could do to get this working? I was going to look at making some custom poster lists and figured the remote would be the easiest way. smile.gif
Thanks again for all of your help!
post #36 of 2417 Old 12-03-2012, 11:33 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Currently MoviePoster doesn't pull from any online sources for TV series. But it will (in xbmc v11 anyway) display the thumbnail thats in the xbmc library for the episode. So if you have pretty fan art there it will be displayed by movie poster. Otherwise you'll get the default xbmc logo. I looked into it though and it looks like TVDB has an open api that i can leverage to pull TV Show information. I'll look into adding support for pulling info fromm them in a future release. Im not sure if it will make the pending frodo fix release though.
I'm aware of the long tagline issue, but honestly it never bothered me enough to fix it. I'll add that to my to do list as well.
Im not sure what could be causing your issue in accessing the web remote unless your firewall is blocking it, or something else is using port 8082. I'll add some more verbose logging to the next release to see if we can track down whats going wrong.
meyer64 is offline
post #37 of 2417 Old 12-03-2012, 12:45 PM
crud's Avatar
This is an awesome app, exactly what I've been looking for. Thank you for this, cannot wait to figure out how to utilize this in my "theater" I'm still playing with the settings and learning.
Quick question though, I want to only use covers from movies that are in my collection. I have them all saved locally to the specified subfolder of my ripped movies. IE Movies/Dark Knight Rises/cover.jpeg. How do do this?
crud is offline
post #38 of 2417 Old 12-04-2012, 04:16 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
There currently isn't support for doing a mass import of all the posters In your xbmc library, however it will cache posters for movies when they are played. So you could go though your xbmc library and just play the ones you want to see posters for. I do have some code in place for doing a mass import, but it has trouble with large libraries so it's currently disabled.
I'm pleased to say that initial support for xbmc 12 frodo is coming along well. It's working on my dev machine, but I want to do a bit more testing before I release it.
meyer64 is offline
post #39 of 2417 Old 12-04-2012, 04:46 PM
post #40 of 2417 Old 12-06-2012, 11:56 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Version 1.0.1.3 is uploaded to SourceForge.
BUG FIX:
-tagline now scales to fit display width when needed.
-Fixed bug where MoviePoster would Freeze if XBMC was closed during playback.
BEHIND THE SCENES:
-initial support for XBMC v12 'Frodo'
-improved support for TV shows. - now pulls metadata for the episode and the poster for the series from xbmc.
-improved support of thumbnail for media not in the library - ie movie trailers
Unfortunately, Sourceforge is having some trouble with their file uploads, so you can't see it on their site quite yet. I'll post an update when the file is able to be downloaded.
meyer64 is offline
post #41 of 2417 Old 12-07-2012, 10:40 AM
cnm
cnm's Avatar
Thank you for even more improvements to this nifty program - I was finally able to nab some time to try it out last night; I was floored by how intuitive and responsive the web-based remote was! Really impressed, I'll definitively be making a donation to help your efforts!
Here are my experiences/thoughts:
1. Trailers and Coming Soon worked exactly the expected way after following the steps in your readme, no problems there whatsoever!
2. I believe that I experienced the same issues fallenangel1 did earlier in the thread when I fired up XBMC - once I started a movie, it 'froze' on whatever Coming Soon poster was currently showing, and reset to the home
Great Dane' theater page once I stopped the movie - I couldn't get the 'Now Playing' to show with the currently showing poster/metadata after several attempts. I still haven't figured out what I'm doing wrong, but in the bottom right hand of the poster, it did say 'Connected' once I started XBMC, at least. I'm using stable Eden - since it was thought that the issues fallenangel1 encountered were Frodo-related, I thought you might want to look at my log file? I'm thinking something else might be the culprit for this problem. Here's the log snippet where it happened:
logfile.txt 3k .txt file
It looks like the error specifically was: 12/7/2012 2:33:26 AM - Error updating media information from XBMC - Object reference not set to an instance of an object.
Also, some feature suggestions/requests that I thought would be neat enhancements:
1. I think you're moving in this direction anyway based on your 'to do' list in the readme, but I think utilizing locally stored trailers/posters would be a great feature to have - for instance, sometimes TMDB doesn't have the particular poster you want for a movie (or at a high enough resolution), but that way you could essentially pick the poster you wanted from anywhere, move it to a folder on your PC, and then have that one added to movieposter's cache instead. Same with trailers, you wouldn't have to worry about whether the youtube link is working, etc. Maybe when you select the 'Choose Alternate Poster' option in the cache view, there could be an option for 'Browse for local poster' or something to that effect, where you could select a poster on your hard drive (doesn't necessarily have to already be in your XBMC library), and maybe the same for trailers?
2. I didn't see this as an option, and please correct me if it's already there..I do like being able to hit the Remote 'Play Trailer' button when I want to see a trailer play for sure, but as of right now, it's strictly a manual process? I thought it would be cool to create a custom list of posters where I want to have the trailers shown for all of them, and have them show a poster, hold for a specific period of time on the poster, and then automatically start the trailer...after the trailer is done, show the next poster, hold for a specific period of time, and then etc. Would be really neat for showcasing!
3. Maybe an option remove the 'eye' on the poster? I know it serves a functional trailer purpose, but I think if you weren't planning on playing trailers (or had them automated), it would be useful to have it not show...or maybe it could be moved to somewhere below the poster, a little less obtrusive? The posters look so clean without it, is all...wink.gif
Again, I really appreciate the work you put into this great program!
cnm is offline
post #42 of 2417 Old 12-07-2012, 11:44 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
I'll do some testing and see if i can replicate the error on my dev machine. At first glance though, there are two significant errors in the log:
The one you mentioned:
and this one:
12/7/2012 2:33:11 AM - run timer elapsed, but it looks like xbmc is connected - error getting active players
the second one usually indicates that there is a problem with MoviePoster connecting to the XBMC http server. Please double check to make sure the http port in Movie poster matches the setting in xbmc (default port 8080). and that the http server is turned on in xbmc. It might also help to specify a password for the http interface if you dont have one.
Now, on to your feature suggestions......
1. this one has been on my mind for a while. Especially local storage of trailers. My internet connection isnt particularly fast and i tend to get stuttering issues when streaming higher quality videos. a local copy would resolve that. Currently, if you want to manually download a poster and add it to the cache, it is possible. But due to the file structure, its not really user friendly. Once I revamp the cache structure it should be much easier.
2. currently its a manual process to play the trailers, yes. you can either use the web remote, click the 'eye' icon, or press the t key if you have a keyboard/remote hooked up. i had thought about adding an auto-play option, but i didnt know if i'd want trailers continually playing, so i never did. I'll add it to the next release though. It should be pretty easy.
3. agreed. i actually had it there mostly for my testing so i could easily see which movies had a trailer and just click the icon to play them. The next release will have an option to hide it.
meyer64 is offline
post #43 of 2417 Old 12-07-2012, 12:12 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Now that i think about it. There is an option in the XBMC network settings to allow other programs to control xbmc. Make sure thats turned on too.
meyer64 is offline
post #44 of 2417 Old 12-08-2012, 09:20 AM
cnm
cnm's Avatar
That did the trick; 'Now Playing' and XBMC integration both working beautifully now, thank you!biggrin.gif
cnm is offline
post #45 of 2417 Old 12-08-2012, 09:38 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Great! I'm glad its working for you.
I've been working on adding requested features and am testing the following before the next release depending on time constraints i might work on the local trailer download support, but i dont want to keep you waiting too long ...
FEATURES:
-option to hide trailer icon
-option to auto-play trailers
-support for Trivia Slides with Q&A
----separate timer interval than posters
----configurable frequency of appearance
meyer64 is offline
post #46 of 2417 Old 12-08-2012, 02:27 PM
I went off radar for a few days, love the update Brent!! Now Playing seems to be working well! I liked it so much I decided to stop watching it on a TV turned on it side and built this from a 32" TV I had laying around! smile.gif
You can see all of the pics I took of the build here;
https://plus.google.com/u/0/photos/106177607191254337017/albums/5819701860507729697
BEFORE!!
post #47 of 2417 Old 12-08-2012, 06:57 PM
So .. after having this up and most of this evening, "Now Playing" is working much better than it was, however, it does seem to lock up once and a while. Ill attach a log, the start of the log it was pulling from cache and I started a show and it just locked up and didnt do anything until I stopped that show and started another movie. Then after a minute or so the poster popped up. It happened earlier and I just restarted MP and it pulled the poster info and worked just fine. Not too sure what it could be .. its working but something is causing an "glitch" once and a while.
log.rtf 13k .rtf file
It also doent seem to like it when I stop a movie in the middle and start another one. I just did that and the Start/End times changed but the poster stayed the same.
post #48 of 2417 Old 12-08-2012, 07:40 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Your frame looks great! It looks like you used a very similar technique to the one I built. I like it smile.gif I have my speakers rear firing in almost the exact location as yours too!
Are your problems with the now playing screen only occurring when you view a TV show? I admit I only have a few episodes in my library, so testing on that is pretty minimal. Did you happen to notice if it was downloading new poster data (spinning gear in the lower left) or in the process of loading another poster (spinning circle thing) when you were experiencing the errors?
meyer64 is offline
post #49 of 2417 Old 12-09-2012, 08:01 AM
Thanks, I saw you're frame and the molding you picked up I liked it as well. So I ran with it. smile.gif I finally got to use the Logan framing equipment I got last Christmas! wink.gif I just wish I had a newer/thinner TV to work with. But that would have cost me $200-400 more. I'm OK with this for now, I may look into rebuilding another one later down the road.
As for my issues, I watch a lot of TV shows so by default most of my issues seem to happen when I'm watching them. But this morning I decided to test it out. The HTPC was on all night, so I just had to turn the screens on. MP was already running, but I had to open XMBC. MP wasnt maximized, and when I maximized it it shifter over to my main TV screen. I had to move it back over to the poster screen and maximize it again. Then I got into XMBC and started the movie 'Invasion'. The gears started spinning, then after a few minutes the gears disappeared and the poster stayed the same 'American Beauty'. I then closed and reopened MP and with in seconds it popped up with now playing and the poster for 'Invasion'. So, it is working .. just something seems to lock it up once and again.
I know you say you do a lot of work in your dev machine, if you want to poke around in my HTPC sometime and see if there is anything that is significantly different. I can set up set up a remote session and let you do some digging.
post #50 of 2417 Old 12-09-2012, 09:16 AM
I've been putting it through some hoops today, I just finished watching 'Invasion' so I started another movie and it was fine, I stopped that movie and started another with no issues. Then I thought, what if I don't "stop" the movie I'm watching and I just start another? So I tried that, while the movies playing I just back up to the menu and start another movie. It worked once and locked up on another. No gears or spinning circles. When it locked up I stopped the movie and started the same movie and MP posted up the correct poster almost immediately. I'm not sure how you have it set up, but it seems like when I 'stop' a movie it resets MP, it goes back to the Great Dane screen and then picks up again. But if I just start another movie while its playing it doesn't get that chance to reboot itself. I'm not sure if that helps or means anything to you, just figured that I'd pass the info along, "Knowing is Half the Battle!" smile.gif
post #51 of 2417 Old 12-09-2012, 11:22 AM
Some more info, same kind of issues. Finished with another movie, backed out without stopping the movie. Started another and it froze up on the old Now Playing screen. No gears or circles, stopped the movie let a cached poster pop up as coming soon. tried another movie and it froze up on the coming soon screen, no circles or gears. Tried that a couple times, and had pretty much the same results .. either the Coming Soon screen would lock up or the Great Dane now showing screen would appear and lock up, at no time would I see gears or circles.
Here's my log with some notes on what I think its doing at that point.
Log2.rtf 36k .rtf file
post #52 of 2417 Old 12-09-2012, 11:55 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Yeah, for some reason its missing the notification from xbmc that new media playback has started. I'm adding some extra checks in the next release that should help. Its ugly code, but i think it will fix the issue for you.
meyer64 is offline
post #53 of 2417 Old 12-09-2012, 12:38 PM
post #54 of 2417 Old 12-09-2012, 05:49 PM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
This is very intriguing - just subscribed !
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #55 of 2417 Old 12-11-2012, 02:43 PM
tewanchuk's Avatar
Love this. Absolutely a must have in my dedicated home theater. Any thoughts on adding the ability to play "local video/trailers" at start-up? Was thinking it would be great to have a custom trailer/intro that plays when the app starts up before going into the "Coming Soon" slide show.
tewanchuk is offline
post #56 of 2417 Old 12-11-2012, 03:07 PM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Yes, that has crossed my mind. Would you be interested in making a sample video? Would you want it to play in the normal video location where the trailers are, in the poster display area, or full screen ? I've also thought about occasionally displaying theater features and playing a demo video for them, like the Dolby/DTS demo videos. What do you think?
meyer64 is offline
post #57 of 2417 Old 12-12-2012, 09:49 AM
tewanchuk's Avatar
Basically was thinking of the following sequence
1. Home Page
2. Intro video ( DTS/Dolby Intro or some other custom video)
3. Coming soon posters / trailers
I would like to see the Intro video centered in the middle of the marquee where the posters are typically displayed... since most of us would have some sort of LCD in a portrait orientation, having it full screen would be tough to do.
post #58 of 2417 Old 12-14-2012, 07:04 AM
crud's Avatar
when trying to use the remote on the local machine I keep getting the following error:
500 - Internal Server Error
System.IO.DirectoryNotFoundException: Could not find a part of the path 'F:\xbmc\release 1.0.1.3\Cache\Movies\lists'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.CommonInit()
at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
at System.IO.Directory.GetFiles(String path, String searchPattern)
at MoviePoster.CustomLists.getCustomLists()
at MoviePoster.processModule.handleRemote(RequestContext context)
at MoviePoster.processModule.Process(RequestContext context)
at HttpServer.Server.ProcessModules(RequestContext context)
at HttpServer.Server.HandleRequest(RequestEventArgs e)
at HttpServer.Server.OnRequest(Object sender, RequestEventArgs e)
I had it work once before last week. I have tried a handful of different ports but they all lead to a nunknown internet page.
crud is offline
post #59 of 2417 Old 12-14-2012, 07:21 AM - Thread Starter
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
Does the F:\xbmc\release 1.0.1.3\Cache\Movies\lists directory exist? it looks like its having trouble finding that folder.
meyer64 is offline
post #60 of 2417 Old 12-14-2012, 08:09 AM
crud's Avatar
ah that was it, thought it was a txt file and I tried to recreate it. I must have have deleted it getting rid of the unwanted downloaded posters that aren't from my xbmc cache. I cannot get that to work either but I'm still tinkering
Apparently trying to quit smoking is frying my brain that I missed a whole dir. Thanks!
crud is offline
Reply Theater Room Items & Accessories
