MoviePoster - Virtual movie poster display software. - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #631 of 2322 Old 01-25-2014, 05:40 PM
Lunatixz's Avatar
Was URL adding/removing Showtime's fixed?
Sent from my SGH-T999 using Tapatalk
Lunatixz is offline
post #632 of 2322 Old 01-27-2014, 11:43 AM
agent62's Avatar
Im loving the app Meyer. Currently running on an old 17" flat panel but look forward to finding something bigger and making a custom box for it.
I just wanted to share the Theater image I made and a pic of my room. Thanks for the hard work!
agent62 is offline
post #633 of 2322 Old 01-29-2014, 12:56 PM
loma's Avatar
Quoted: 21 Post(s)
Nice. What font is that?
loma is offline
post #634 of 2322 Old 01-30-2014, 06:58 AM
agent62's Avatar
Tnx.
Its Edwardian Script ITC.
agent62 is offline
post #635 of 2322 Old 01-30-2014, 08:26 AM
loma's Avatar
Quoted: 21 Post(s)
Tnx.
loma is offline
post #636 of 2322 Old 01-31-2014, 11:47 AM
loma's Avatar
Quoted: 21 Post(s)
@meyer. Any ETA re MB3?
loma is offline
post #637 of 2322 Old 01-31-2014, 11:53 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Unfortunately, I broke my leg and since my main dev and test machines are in my basement development has been pretty slow lately. I'm not quite as productive on my 11” net book. I haven't forgotten though and it is coming.
meyer64 is offline
post #638 of 2322 Old 01-31-2014, 12:54 PM
loma's Avatar
Quoted: 21 Post(s)
Thanks. Sorry to hear of your accident. May you have a speedy recovery.
loma is offline
post #639 of 2322 Old 01-31-2014, 02:37 PM
loma's Avatar
Quoted: 21 Post(s)
In preparation for MB3, I have been playing with xbmc. I noticed that with display options-dim screen for "Now Playing" box unticked, now playing still dims. How can I prevent it from dimming? Thanks.
Now playing shows the backdrop. How can I get it to show the poster? (solved this)
@meyer: changed back from preview release. There was no dimming of the poster display.
loma is offline
post #640 of 2322 Old 02-02-2014, 08:07 PM
MorphWS6's Avatar
I must be an idiot when it comes to this stuff. I still can't get mine to work at all. Oh well, I guess I'll wait until something more user friendly comes along.
MorphWS6 is offline
post #641 of 2322 Old 02-03-2014, 01:51 PM
sraptor's Avatar
Can not be more friendly, it is so easy to setup and use.
I gave to developer a 10 score from 10
sraptor is offline
post #642 of 2322 Old 02-03-2014, 04:38 PM
agent62's Avatar
MorphW86:
I had problems getting it to show Now Playing. It didn't run because I was running the development Gotham Build of XBMC. I switched back to the stable Frodo release of XBMC and wala. it fired right up.
agent62 is offline
post #643 of 2322 Old 02-06-2014, 07:23 AM
BeckHTPC's Avatar
Thanks meyer64 for the application, a donation is on the way!
I do have a concern/observation with the application. After installation on a physical machine, my XBMC video playback became stuttered and choppy from the get-go. The .NET install prompt for 4.5 was redirected to 4.5.1 (which was then installed). Trouble shooting, I removed all the .NET installs and the MoviePoster app. This did not resolve the video playback issue. I reluctantly re-installed XMBC 12.3 and the video was still choppy. What could the MoviePoster app or .NET have done with the video?
I attempted to reproduce the issue on a VM of mine and did so without issue. A plain vanilla XBMC 12.3 install and the MoviePoster app. Going forward, I configured the app with the IP and password to allow communication to XBMC and Voila! the play back is good...on the VM anyhow.  When I applied this to the physical HTPC, all did not go so well even with the proper credentials.
Bare in mind, this is not my physical HTPC, and the owners will certainly want to know what the holdup is...any idea's on this? I'll produce a log and more info if needed. Thanks in advance!
MoviePoster v1.0.1.6
Physical HTPC:
Windows 7 x64
AMD A4 5300 3.6ghz APU
40 gb Mushkin Callisto SSD
4GB G.SkillDDR-1600 PC3-12800
MSI FM2-A75MA Motherboard
VM:
Windows 7 x64
3 GB memory
BeckHTPC is offline
post #644 of 2322 Old 02-06-2014, 08:01 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Hmmm... I haven't ever noticed any playback problems with XBMC when using MoviePoster. The trailer playback in MoviePoster doesn't take advantage of hardware decoding, so it can use more CPU resources with higher resolution video. But that would only occur when a trailer is actually playing. MoviePoster doesn't touch the XBMC install in any way, and as far as I know XBMC doesn't use .Net for anything either. I'd guess that the playback issues arent directly related to MoviePoster. First thing I'd check is video card drivers and make sure you are using DXVA decoding in XBMC. I know HD audio can cause playback issues in XBMC also. Make sure that if you're playing files with HD audio, that you either have HD audio passthrough turned off or that your receiver actually supports HD audio decoding.
meyer64 is offline
post #645 of 2322 Old 02-06-2014, 04:44 PM
BeckHTPC's Avatar
Thanks for the advice Meyer64, all the suggestions did not change the strange performance with this machine...seems to be another issue that occurred that I'll have to delve deeper into.  My donation stands (and has been sent) in the hopes that your project continues,...I'll use this on my own machine.
BeckHTPC is offline
post #646 of 2322 Old 02-06-2014, 06:13 PM
BeckHTPC's Avatar
For what it's worth, I found the Issue.  It was the audio output.  Building the HTPC, I don't have a 5.1 in my shop, so I use headphones in the front jack to check audio quality. When done, I remove the headphones from the jack. I haven't used them again until the MoviePoster application install to check the audio quality of the previews. Whatever is happening occurs with the front audio jack and how it is set up.  If anyone is interested, I'll post XBMC logs and MoviePoster info.
The system setup at the theater location is a 5.1 Onkyo AVX-290 with HDMI pass-through, which is what the XBMC was setup to use. The motherboard seemingly has issues on where/how to pass the audio through then the HDMI is absent. In my shop, I use the onboard DVI for video output and front jack for audio.
This only took me a few hours to figure out, better than a few days!
BeckHTPC is offline
post #647 of 2322 Old 02-07-2014, 07:41 PM
BeckHTPC's Avatar
Alright, I have this working perfectly on my personal HTPC, registered and all. Thanks.  Now for a few suggestions:
1) Hash the password in 'connection options'.
2) Add check option to start with 'xbmc.exe' (delayed start).
3) Field entry for custom location of images and preview video's. (Suppose the application is installed on a fast 40gb SSD, I'll like to keep the large image files on a different drive/location rather than default windows C:)
Just a thought...Thank you again for this, well worth the donation!
BeckHTPC is offline
post #648 of 2322 Old 02-09-2014, 08:08 PM
dth122's Avatar
Quoted: 24 Post(s)
I'm having a problem getting trailers to play. When I try to start them, I get a black box for about 30 seconds or a minute, then it clears and shows the poster. When I try to player the trailers from the cache directory using VLC, they work fine. Any idea what's going on?
Also - is there any way to give priority to movies with motion posters? They are so cool that it would be nice to have them come up a little bit more than the static images.
- Dave
dth122 is offline
post #649 of 2322 Old 02-10-2014, 02:36 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
- Dave
Make sure your graphics drivers are up to date. Movieposter uses DirectX for rendering the video. If directX isnt installed or supported by your graphics drivers, it could cause problems.
I'm working on a priority system for a future release so your higher rated posters will show more. I dont have an ETA, but it will be supported eventually.
meyer64 is offline
post #650 of 2322 Old 02-10-2014, 09:33 PM
dth122's Avatar
Quoted: 24 Post(s)
That's cool about the ratings. It will be nice to have when it's ready.
Still having the trailer problem...
I'm running Win7/64 on a Zotac ID41. Just installed the NVIDIA drivers from Jan 7. dxdiag reports DirectX 11 installed and working properly. The trailers play fine in VLC.
Not sure what else it could be. The fact that the black box stays up for a period of time seems to me to indicate that it's playing, just not decoding video for some reason.
- Dave
dth122 is offline
post #651 of 2322 Old 02-22-2014, 07:39 PM
sraptor's Avatar
Can you make the software to can ajust screen size, like xbmc. When I did the frame it is a little smaller than screen, your be nice to have the option I can ajust screen from the software.
Let me know if that can be made.
sraptor is offline
post #652 of 2322 Old 02-25-2014, 07:29 PM
loma's Avatar
Quoted: 21 Post(s)
@meyer: How is recovery? Would love an update on the next release also.
agent62 likes this.
loma is offline
post #653 of 2322 Old 02-28-2014, 06:32 AM
eecyclone's Avatar
I finally found a good deal for a 37" 1080p LCD on craigslist! It's a vizio and its only 2.2" deep so hopefully it will look great once I mount it and build a frame for it. Although I'm not sure when I''ll have time for that. I love seeing the pictures of everyone else's frames and getting ideas for what I want mine to look like.
eecyclone is offline
post #654 of 2322 Old 02-28-2014, 07:18 AM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 185
Good luck with it and it is a pretty cool when people come over. I do love the fact that if the movie poster app is running and I play a movie on my main TV that the movie poster app will dim, thus being less distracting for viewing the main movie. I have both the main and movie poster in same room. Would be different if I had Movie poster mounted outside my theater, but I think you can set the dim up in settings, so it won't dim if you did mount outside of your theater.
I didn't take my frame off my 32" TV and made my frame to fit over the TV. I did this just for the fact that I could use the TV again, if I needed to. If I were to build it in a wall I definitely would take the frame off and mount the speakers else where.
The Elusive 1099 (L/C/R)---DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #655 of 2322 Old 03-04-2014, 07:44 AM
sraptor's Avatar
Meyer64 how is your recovery? I almost got my PIR ready, and I will send picture of the frame.
sraptor is offline
post #656 of 2322 Old 03-04-2014, 03:25 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Recovery is going well. Hopefully I'll be back on two feet in a couple weeks. I've been meaning to send you a wiring diagram for the motion sensor. I just need to get it drawn up.
meyer64 is offline
post #657 of 2322 Old 03-04-2014, 08:05 PM
sraptor's Avatar
Meyer in your relay you add any resistor?
I think I ready have mine setup with arduino card, After I test it I will do in the tensys. my output from power tv is 3.3v. Do you have to put any resistor tv button and relay?
sraptor is offline
post #658 of 2322 Old 03-13-2014, 08:29 PM
Daniel Chaves's Avatar
Quoted: 409 Post(s)
Liked: 302
wow I plan to donate right away, this is awesome, I hope one day it will work with MediaBrowser3.com (if it is and I missed it, my bad still going through all the pages)
Edit: I made a small donation for now, when I fully start utilizing this software I will donate again and if I see support for other programs like MediaBrowser I will make another donation on top of the last ones smile.gif
Also anyone having any issues trying to get this to work with version 13 beta? what is the most stable version of XBMC that this currently works on so I can install that version?
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #659 of 2322 Old 03-15-2014, 12:31 PM
fierce_gt's Avatar
Quoted: 1644 Post(s)
Liked: 1586
mine doesn't seem to be downloaded trailers anymore.
added a bunch of new movies the other day, and it grabbed the posters as usual, but no trailers. gave it a day to see if anything happened, still no trailers. so I 'uninstalled' and reinstalled it today, made no difference.
on the plus, I also tried the beta version today, and I'm liking it so far, some nice changes in functionality and I find it easier to use the settings menu. just don't know what happened that made it stop downloading trailers.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #660 of 2322 Old 03-15-2014, 04:54 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
I havent done any testing with XBMC 13 yet. 12.x should be fully supported though.
meyer64 is offline
Reply Theater Room Items & Accessories
