MoviePoster - Virtual movie poster display software. - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #721 of 2322 Old 04-10-2014, 07:17 PM
sraptor's Avatar
Colton, very nice. i just finished my sensor.
Meyer in your code if you connect usb direct to a power supply is not working right, only if you connect to a led source from the tv and hook it to the computer.
I put inside of the frame a mini computer nuc, and I going to add another relay to start the computer first before than tv. I will let you know my progress.
sraptor is offline
post #722 of 2322 Old 04-10-2014, 07:24 PM
sraptor's Avatar
I made this arcade machine for my room also.
sraptor is offline
post #723 of 2322 Old 04-10-2014, 07:25 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
you still need to connect to the led no matter how the board is powered. it shouldn't matter at all if the board is powered from USB or some other 5v source, as long as the 5v is on all the time. if you try to run it from a usb port on the tv, it might lose power when the tv turns off.
meyer64 is online now
post #724 of 2322 Old 04-10-2014, 07:25 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Very nice! I've been thinking of building one also.
post #725 of 2322 Old 04-10-2014, 07:44 PM
sraptor's Avatar
Meyer, when you are ready to built one let me know, maybe I can help you with the parts I used. I built that one 4 years ago.
sraptor is offline
post #726 of 2322 Old 04-10-2014, 08:03 PM
sraptor's Avatar
Here is the picture of my sensor.
sraptor is offline
post #727 of 2322 Old 04-10-2014, 08:31 PM
Daniel Chaves's Avatar
Quoted: 409 Post(s)
Liked: 303
I use to own Buck Rogers Pinball Machine and an Original PacMan machine but had to sell them when I moved to LA... man I miss those but yeah one day I hope to have a spot for some arcade machines too ^_^
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #728 of 2322 Old 04-10-2014, 08:39 PM
sraptor's Avatar
Daniel, I enjoyed more building it than playing it.
It work great but more fun was to figure out how to make it work.
sraptor is offline
post #729 of 2322 Old 04-10-2014, 10:24 PM
Colton's Avatar
Thanks, Daniel.
Here is a thread to get you started: http://www.avsforum.com/t/1280351/my-loft-theater-is-finished
The ticket booth thread is here: http://www.avsforum.com/t/680611/the-ticket-booth-experience
-Colton
Daniel Chaves likes this.
Colton is offline
post #730 of 2322 Old 04-10-2014, 10:56 PM
Colton's Avatar
Meyer:
The wall switch that turns off the power to both TVs cuts the power completely, so if MoviePoster is playing, it defaults back to my big screen. The only option would for me to manually turn off MoviePoster BEFORE flipping the wall switch in order to keep the settings. Is there another way for me to fix this?
-Colton
Colton is offline
post #731 of 2322 Old 04-11-2014, 04:02 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Originally Posted by Colton View Post
Meyer:
-Colton
not in the current release, unfortunately, windows tries to help you by moving apps around when a display becomes unavailable, but i do have a solution implemented for the next release. i just need to fix a bug that causes the display to freeze after running for a day or so. I've been making small improvements, adding error checking, and improving efficiency, but I still haven't squashed that tricky bug yet. I wouldnt mind letting you try it out if you want, but i really cant consider it stable at this point.
post #732 of 2322 Old 04-11-2014, 05:45 AM
Colton's Avatar
I'd be happy to test it. You know my e-mail address.
-Colton
Colton is offline
post #733 of 2322 Old 04-13-2014, 07:53 PM
sraptor's Avatar
Meyer , what is the setup you do to stay on poster when you are watching a movie?
Baud rate: 38400
data bits: 8
Handshake: ?
Parity: ?
Stop Bits: ?
sraptor is offline
post #734 of 2322 Old 04-14-2014, 08:35 PM
sraptor's Avatar
I figured out the setting and not I got working.
Meyer, can you make an option if I put picture from one folder only show picture from that folder? Only pictures.
That is good if you want to put picture is not movies.
sraptor is offline
post #735 of 2322 Old 04-15-2014, 12:52 AM
tsleon's Avatar
Meyer:
-Colton
Hdmi tape trick solved my same problem. http://forum.xbmc.org/showthread.php?tid=158432
tsleon is offline
post #736 of 2322 Old 04-16-2014, 01:09 PM
Colton's Avatar
This is the right pin to block.
Colton is offline
post #737 of 2322 Old 04-16-2014, 01:17 PM
Quoted: 409 Post(s)
Liked: 303
So there is no confusion, in the picture being shown, the pin that is taped is the correct pin to cover.
The pin being stated to be blocked in that picture is not the correct pin.
post #738 of 2322 Old 04-16-2014, 01:23 PM
Colton's Avatar
Yes, further reading does show that the original photo of the taped pin is the right one.
Colton is offline
post #739 of 2322 Old 04-18-2014, 11:31 PM
Dizzy49's Avatar
Quoted: 35 Post(s)
Liked: 30
This is cool as hell, and I want to build a display as well.
How does it handle when playing TV Shows vs Movies in XBMC?
Sean Hull
Denon 3808ci | PS3 80Gb | Harmony One | Toshiba XA2 | Samsung 61" PN60E6500EF | HTPC with HDMI
Dizzy49 is offline
post #740 of 2322 Old 04-19-2014, 08:29 AM
Colton's Avatar
Meyer, sometimes I play music before the movie ... how about a feature that downloads a photo of the singer? So, if I'm playing 80's music and "Don't Stop Believing" plays ... MoviePoster will show a photo of Journey?
By the way, I try to connect to the web remote using my Android tablet and Windows 7 desktop computer and both can't access it at 127.0.0.1:8082/remote.html. What do I need to do to fix that?
-Colton
Colton is offline
post #741 of 2322 Old 04-19-2014, 07:53 PM
sraptor's Avatar
The ip you should connect is the ip from the poster virtual software.
sraptor is offline
post #742 of 2322 Old 04-19-2014, 08:50 PM
Colton's Avatar
The IP of the computer that MoviePoster is on?
Yup! That was it! Working now ...
Thanks, sraptor!
One last thing, I noticed the trailers don't play. I have them enabled, but a small black boxs pops up and then disappears.
-Colton
Colton is offline
post #743 of 2322 Old 04-20-2014, 07:27 AM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 185
-Colton
If you are playing music, tv shows or movies from XBMC and have fanart and covers in the local folders for the artist,tv show or movie, Movie poster will display "Now Showing" with the cover art or fanart along with the start and end times of the song, tv show and movie
The web remote does not work with the current version. I posted that problem a while back.
The Elusive 1099 (L/C/R)---DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #744 of 2322 Old 04-20-2014, 03:42 PM
Dizzy49's Avatar
Quoted: 35 Post(s)
Liked: 30
Anyone tried using a touch screen with this? Thought it might be nice to be show a static image, and then can press a button to watch the trailer, or maybe search the movie collection.
Sean Hull
Dizzy49 is offline
post #745 of 2322 Old 04-21-2014, 06:54 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
i considered the idea of touch features back when I first started the project. But the cost of a large touch capable lcd was too high for me to really consider it practical for most people. HP does make a 42" touch monitor that can be found on eBay from time to time that would probably make a great MoviePoster display. I believe I left an option in to 'show trailer icon' or something like that. If you click (or touch) that icon it would start the trailer playback. I also considered using the Microsoft Kinect camera to allow for gesture control, but i don't have one, so that never went anywhere.
post #746 of 2322 Old 04-21-2014, 06:59 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
Thanks, sraptor!
-Colton
It looks like something broke in the youtube downloader. thankfully, its easy to fix. I'll update the downloads soon, I finally tracked down a nasty memory leak last night, so I'm to a point where i just need to tie up loose ends before the next release. but if you want to fix it yourself, you can download the newest version of youtube-dl here:
http://rg3.github.io/youtube-dl/download.html
download the windows version and replace the youtube-dl.exe file in the movieposter/mplayer directory with it.
post #747 of 2322 Old 04-21-2014, 11:29 AM
Colton's Avatar
That's great news, Meyer! Thanks for all your help!
UPDATE:
Downloaded new file and over-wrote the old file. No change. Black box opens ... then closes.
-Colton
Colton is offline
post #748 of 2322 Old 04-21-2014, 09:10 PM
dth122's Avatar
Quoted: 25 Post(s)
You may have the same problem I had. For some reason, mplayer needs to prep/cache a TON of fonts, even though they're never used. It seems that Movie Poster never lets mplayer run long enough to do all of its prep work. The fix was to run mplayer separately from Movie Poster once and let it do its thing. After that it worked fine for me.
- Dave
dth122 is offline
post #749 of 2322 Old 04-21-2014, 09:31 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
- Dave
yes, that is likely whats happening if your youtube-dl is up to date and you still get the black box. I have resolved the mplayer font cache issue for the next release, which will hopefully be ready soon.
post #750 of 2322 Old 04-21-2014, 10:18 PM
sraptor's Avatar
meyer64,
Do you know if movieposter work with plex? I tried it and I can not make it work, plex is a nice system also and it is coming from xbmc.
sraptor is offline
Reply Theater Room Items & Accessories
