MoviePoster - Virtual movie poster display software. - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #901 of 2322 Old 08-26-2014, 07:04 AM
Liked: 0
Is it possible to map the trailer 'T' shortcut key to a different key? I want to use a pushbutton and Teensy to map the button to the keyboard so someone can push the button to watch the trailer. But I plan to put up 2 of these and run 2 instances of Movie Poster and would like to be able to have a push button for each poster to be able to play the trailer.
This is probably one of the coolest apps I've seen, even my wife was impressed Thanks for all your hard work and donation coming shortly!
merlin00 is offline
post #902 of 2322 Old 08-27-2014, 12:47 PM
Liked: 0
good job!
I use this movie poster software for create posters. Its very easy and fast. Somewhat later I will let down my posters here
grols is offline
post #903 of 2322 Old 08-29-2014, 09:10 AM
sraptor's Avatar
This is what I used for what you say.
http://pcsensor.com/index.php?_a=product&product_id=102
sraptor is offline
post #904 of 2322 Old 08-29-2014, 10:51 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Originally Posted by meyer64 View Post
Also, just to share another project idea of mine:
I didn't want to leave the poster display on all the time and it is a bit tedious to have to turn it on and off all the time. So I designed a solution to use a Teensy USB development board (like an arduino) , a PIR motion sensor, and some relays to control the screen. the plan is that the device will watch for motion in the area, turn on the screen and wakes up the PC. When no motion is detected for say 30 minutes, it turns the screen off. It will monitor the power state of the screen so it wont send the 'power on' button press if the screen is already on. This will be independent of the PC, so it can be used even if the PC is set to go to standby after a set amount of time. The Teensy can send a simulated keyboard event over USB to wake the PC in this case.
I have my motion sensor project working! I used a PIR motion sensor, a Teensy USB development board, and an arduino relay module.
This is my PIR motion sensor:
for now I just set it on top of the poster display, but eventually I'll make a nice housing for it and either wall or ceiling mount it.
It has a 3 pin connector, with +5v, ground, and +3.3v signal output. the signal output goes high when motion is detected and low when there is no motion.
the +5v and ground are supplied by the usb connection to the Teensy board. the 3.3v trigger is connected back to one of the digital inputs on the Teensy.
Also connected to the Teensy Board, is a 5v arduino relay module. the relay is triggered by one of the Teensy digital IO pins and is wired to the TV's button panel to simulate a button push on the power button. You could also send a power code over IR if you wanted to.
I also have a signal wire running from the IR/LED module to one of the analog inputs on the Teensy. This is used to determine the power state of the TV. when its on, approx 3v is sent to an analog input on the teensy. I chose to use the analog input simply to avoid connecting any extra circuitry to make it work on the digital inputs. (need at least 3.3v to signal HIGH input). this way we only simulate a power button push to turn the tv on if its in the off state, if its already on, the relay doesnt need to be triggered because it would turn the screen off instead.
Once motion is detected, the relay is triggered to turn the screen on. after a set amount of time (i figured 20 minutes was good), the relay is triggered again to turn the screen off. every time motion is detected the timeout is reset, so the screen will stay on as long as there is movement before the 20 min timeout expires. The code i wrote for the Teensy also watches for Strings to be sent over USB-Serial so I can send a command from the MoviePoster software to turn the screen on. For example, I always want the poster display on when a movie is playing, regardless of if motion is detected. this could also be used to turn the display on and off at certain times of day.
This is beautiful,
Just came across this thread. I was contemplating using a digital signage software program that can display posters, videos and all that on a monitor as you do but your program is so much nicer for this purpose.
I'm curious about your motion sensor project. That is exactly how I would want to set up a display. Don't want it on all the time, or deal with turning it on and off. I want it on when it senses motion during certain time of the day and perhaps only on certain days. In fact I just ordered earlier this week a mini motion sensor for a Home Theater Marquee sign that I'm making to turn LED lights on and off. It simply gets wired in to the power supply for turning on and off.
How did yours turn out. I may have missed as I was skimming thru your posts and didn't see it mentioned it again. Does it perform they way you expected it to. I know you list all the products that you used but do you have a rough estimate of cost (I know its been a while but just wondering).
Finally is this project plug and play or is some basic coding required? I would love to do this but not sure I would be able to if that is the case. My son can, so I can call on him for help if it's anything substantial. However, he's gonna out of state and Dad's project probably wouldn't take priority.
Really love what you have done. If I can make this project happen you will have my support.
BTW PLEX user, so if you ever make it work on that platform that would be awesome.
EDIT: Found this helpful post.
Man my wife is gonna kill me when she see's what I wanna do with a flat panel
oman321 is offline
post #905 of 2322 Old 08-29-2014, 11:33 AM
Liked: 0
How did you tell MoviePoster which trailer to start or do you just run the same thing on multiple screens? Or does your solution allow you to enter the program .exe and then a key stroke as well? I like this idea, I just don't want to have 2 different trailers playing at the same time over each other.
merlin00 is offline
post #906 of 2322 Old 08-31-2014, 10:07 AM
Robert Clark's Avatar
Quoted: 49 Post(s)
Liked: 47
Attachment 238721
My cheap Michaels mount for my monitor dressed up a bit.
Robert Clark
Robert Clark is offline
post #907 of 2322 Old 09-08-2014, 10:23 PM
sraptor's Avatar
you run the same thing
sraptor is offline
post #908 of 2322 Old 09-10-2014, 05:32 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Is there a way to incorporate this software into a setup that uses an Oppo 103d as the media device?
the_abbot is offline
post #909 of 2322 Old 09-10-2014, 11:32 AM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
The only way I can think of doing that would be to use Mediabrowser3 and have the Oppo as the playback device using the play to DLNA feature. Then with the integration with Mediabrowser3 movie poster will display the now showing poster... this may also be possible with XBMC but I don't use that software - it would have to go something like this;
MB3 web client (phone/tablet/PC) to browse and select the movie to watch
Play to DLNA
Oppo is render device for DLNA
I can't test anything with movie poster as we are waiting for the new release with MB3 integration, but I will test out the MB3 play to Oppo if that helps for now??
Good luck...
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
post #910 of 2322 Old 09-10-2014, 04:49 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Play to DLNA
Good luck...
That would be awesome! I haven't purchased my Oppo yet, but it will be the centerpiece of my setup when I pick one up next month.
post #911 of 2322 Old 09-19-2014, 07:24 AM
me23's Avatar
Quoted: 14 Post(s)
Meyer, any update? I can't reliably run this without intermittent lookups or blue screens.
me23 is offline
post #912 of 2322 Old 10-02-2014, 08:26 AM
ragedogg69's Avatar
I have run into a bit of an issue. It downloads new posters just fine, however it does not download new trailers to go with them. (even when I tell it manually to do so) Any body have the same issue? I think I am going to do a complete uninstall reinstall and see if that helps.
My DVD Collection
GO CHIEFS, WILDCATS, SUNS, DIAMONDBACKS, COYOTES, RATTLERS, AND LUMBERJACKS!
"Asking if an HDTV is too big, is like me asking you if the diamond on your wedding ring is too big." -- My dad's response to my mom's question about my 65" HDTV.
ragedogg69 is offline
post #913 of 2322 Old 10-03-2014, 05:48 AM
dukedallas2005's Avatar
When will the software be bumped to the next level? 1.7 still a preview?
dukedallas2005 is offline
post #914 of 2322 Old 10-06-2014, 05:50 PM
bugman72's Avatar
I second dukedallas's post. Any word on the next release? I have finally had the chance to revisit this project, as I have a more robust Win7 machine now. Monitor is mounted on the wall and I am able to run 1.0.1.7 Preview with no issues EXCEPT the lack of being able to create custom lists. If I revert back to 1.0.1.6, then it won't talk to my Pi's build of XBMC (13.2 Gotham) and I get nothing when playing a movie. It's connected to the Pi, but MoviePoster just won't show "Now Playing". It freezes the poster that was up at the time and will resume the slideshow as soon as I stop the movie. If I launch 1.0.1.7 again, all is fine with "Now Playing". So, at this point I can either create custom lists and not have "Now Playing" work or no custom lists and a functional "Now Playing".
dukedallas2005 likes this.
"Can I refill your eggnog, Eddie? Drive you out to the middle of nowhere and leave you for dead?"
Greg Jones
My Former Theater...The Escape
My DVD Collection
bugman72 is offline
post #915 of 2322 Old 10-08-2014, 11:54 PM
Colton's Avatar
Is this project dead? Haven't seen any updates in months.
Colton is offline
post #916 of 2322 Old 10-09-2014, 05:45 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
The project is not dead. Unfortunately, life events had taken priority again and I have had next to no time to work on the program. It is likely that 1.0.1.7 will never see a final build. Instead the next release will probably jump to 2.0 as the plugin system along with MB3 support will be major new features. I sincerely apologize that it has taken so long to wrap it up and get it published. I wish I could give you guys a timeframe for the release , but for reasons out of my control my free time is very unpredictable at the moment. I can assure you that the code is close to finished. Everything for the plugins and mb3 is working. It's just not user friendly as far as changing settings. (All hard coded for testing or in XML files, no GUI) I didn't want to release a build that I know would require support from me that I likely wouldn't be able to provide in a timely manner. I'll be re shingling my roof this weekend, then hopefully I'll have time to sit down and get the next build ready for you to use. Thanks for your support.
sucher and Daniel Chaves like this.
meyer64 is online now
post #917 of 2322 Old 10-09-2014, 10:33 AM
fierce_gt's Avatar
Quoted: 1646 Post(s)
Liked: 1587
no worries man. we all appreciate everything you've already done, and the MB3 support is well worth the wait!
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #918 of 2322 Old 10-09-2014, 05:28 PM
me23's Avatar
Quoted: 14 Post(s)
Thanks for the reply Meyer, look forward to it.
me23 is offline
post #919 of 2322 Old 10-19-2014, 07:11 AM
jeffbab's Avatar
Just curious if anyone else has recently had their motion posters stop playing. All I get is a black screen where the motion poster should be. Ones that are in gif format are fine, it just appears to be only ones in format like avi or mov, etc.
I tried playing the files myself by clicking on them manually and they play fine in windows media player, so I don't think there is a codec issue.
This is a dedicated win7 machine that does nothing but sit and run movieposter, so the only things that have changed on it would be regular windows updates. It doesn't get touched otherwise and there is no other software on it.
I guess I can start uninstalling all the recent windows updates from the past week, but I thought I would check here first to see if anyone else was experiencing any issues.
I also noticed that the movie trailers won't play either, but I am not sure if that is a recent development as I haven't tried to watch one in a long time. I tried the youtube dll update mentioned in this thread a while back but that didn't fix it either. I do recall that fixed it a long time ago when I had that issue.
jeffbab is offline
post #920 of 2322 Old 10-23-2014, 12:28 PM
jeffbab's Avatar
Just an FYI for anyone else that ran into this problem. It was definitely the windows updates that caused this. Unfortunately I never bothered to take the time to pinpoint exactly which one did it.
It was one of the updates that got installed around October 17, 2014. There were around 5 regular security updates and around 5 .NET security updates that hit all at once. I just removed them all and disabled windows update completely since I don't really need to keep this machine fully updated.
If I find time maybe I'll go back through and reinstall them one by one to see which one breaks the program.
Removing these also made the "play trailer" function work perfectly again as well.
jeffbab is offline
post #921 of 2322 Old 10-31-2014, 08:22 AM
ragedogg69's Avatar
Yeah I am having that issue with newly downloaded trailers not playing. IE, they are not downloading at all. Previously downloaded trailers play just fine.
How does one remove a windows update. That might be my fix.
My DVD Collection
post #922 of 2322 Old 11-03-2014, 06:26 AM
jeffbab's Avatar
I'm on windows 8 right now, but I think it was basically the same on win7. Go to control panel, windows update, click view update history, then there should be a link in there somewhere that says "installed updates". If you click that it will bring up a list of the updates for you, and you can just right click on the ones you want and hit uninstall.
jeffbab is offline
post #923 of 2322 Old 11-09-2014, 02:38 PM
krh1009's Avatar
meyer64,<br><br>
Do you know if movieposter work with plex? I tried it and I can not make it work, plex is a nice system also and it is coming from xbmc.
Just installed this software, great job!
Has there been any update on the Plex plug-in?
Until there is a plug-in, is there a way to manually set "Now Playing" text to appear, instead of "Coming Soon"?
krh1009 is offline
post #924 of 2322 Old 11-09-2014, 03:00 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
The next release will include a plugin for MediaBrowser3 , Plex will follow soon after. In the current release there is no way to manually alter the 'coming soon' / 'now playing' text. You could poke around in the theme files and rename the banners so that the coming soon banner is really the same image as the now playing banner. but then The banner would always be displayed as Now Playing.
post #925 of 2322 Old 11-28-2014, 05:56 AM
me23's Avatar
Quoted: 14 Post(s)
Hey Meyer, any chance for s nice Black Friday surprise?
me23 is offline
post #926 of 2322 Old 12-16-2014, 11:45 AM
DougUSMC's Avatar
Quoted: 284 Post(s)
Liked: 210
Been planning on this forever, and finally got around to downloading it. I think it's such a great app, I had to make a contribution!
That being said, I could use some help...
I've seen a bunch of similar posts, but I can't figure out what I'm doing wrong. I have a basic installation of XMBC playing, and I'm trying to connect the two. When I enter the connection info, it "seems" to be working, but not 100%? I see "Connected:" at the bottom of the app, but no server name?
Am I wrong that all I have to do is enter the port #s under Settings/Connection Options? I have the IP/username/Password and HTTP port correct ( I can connect to them in a browser), but I'm not sure about the JSONRPC port? I've gone into XBMC a couple of times, enabled "System/Services/Remote Control/ Allow programs on this system to control XBMC" set to true.
I've restarted both a couple of times, and even rebooted the PC, but no luck.
Did I miss something?
DougUSMC is offline
post #927 of 2322 Old 12-16-2014, 11:50 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
What Operating System is your xbmc machine running? If it's Windows 7, you might need to change a firewall rule so the machine responds to ping requests. I think I put a note about it in the reader file. Otherwise I can send you the details later tonight.
post #928 of 2322 Old 12-16-2014, 11:57 AM
DougUSMC's Avatar
Quoted: 284 Post(s)
Liked: 210
I'm running 8.1. Windows already asked me about a firewall rule, and I granted permission. (Both XBMC and MoviePoster).
Does anyone know the default port for the JSON RPC on XMBC? I'm running XBMC 13.2...
DougUSMC is offline
post #929 of 2322 Old 12-16-2014, 12:11 PM
DougUSMC's Avatar
Quoted: 284 Post(s)
Liked: 210
BTW, when I try to use the webremote to select Now Playing, I see this error in the logfile:
Updated to better info:
12/16/2014 3:12:05 PM - Http module: POST
12/16/2014 3:12:05 PM - Http Recieved: http://127.0.0.1:8082/movieposter.ht...showNowPlaying)
12/16/2014 3:12:05 PM - run timer elapsed, but it looks like xbmc is connected - error getting active players
12/16/2014 3:12:05 PM - Show Next
12/16/2014 3:12:05 PM - Getting posterDisplayObject by IMDB: tt0816692
12/16/2014 3:12:05 PM - tt0816692 is in the cache, loading from cache.
12/16/2014 3:12:05 PM - retrieving .nfo: C:\Program Files (x86)\MoviePoster - Version 1.0.1.6\Cache\Movies\tt0816692-Interstellar\tt0816692.nfo
12/16/2014 3:12:05 PM - Interstellar - tt0816692 - has been loaded from the cache.
12/16/2014 3:12:05 PM - Loaded PosterDisplayObject for tt0816692 - Interstellar
12/16/2014 3:12:06 PM - Nothing Is Playing.....Updating From Cache
12/16/2014 3:12:06 PM - Preparing to download trailer for Interstellar
12/16/2014 3:12:06 PM - Youtube-DL output: [youtube] Setting language
12/16/2014 3:12:06 PM - Error Retrieving data from Rotten Tomatoes: The remote server returned an error: (403) Forbidden.
12/16/2014 3:12:06 PM - Updating UI started for Interstellar
12/16/2014 3:12:06 PM - Error getting studio image -
12/16/2014 3:12:06 PM - Error getting resolution image -
12/16/2014 3:12:06 PM - Error getting audio format image - 0
12/16/2014 3:12:06 PM - Updating UI Finished
12/16/2014 3:12:06 PM - temp Pause Off
12/16/2014 3:12:07 PM - Youtube-DL output: [youtube] ePbKGoIGAXY: Downloading video webpage
12/16/2014 3:12:07 PM - Youtube-DL output: [youtube] ePbKGoIGAXY: Downloading video info webpage
12/16/2014 3:12:08 PM - Youtube-DL output: [youtube] ePbKGoIGAXY: Extracting video information
12/16/2014 3:12:08 PM - 720p MP4 Trailer for Interstellar was not saved.
12/16/2014 3:12:08 PM - Trying to download 35 for Interstellar
12/16/2014 3:12:08 PM - Preparing to download trailer for Interstellar
12/16/2014 3:12:08 PM - Youtube-DL output: [youtube] Setting language
DougUSMC is offline
post #930 of 2322 Old 12-16-2014, 01:20 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 238
I see your running movieposter 1.0.1.6. Version 1.0.1.7 has been tested to work with xbmc 13.x. Version 1.0.1.6 works fine with xbmc 12.x though.
Json rpc runs on port 9090 by default.
Reply Theater Room Items & Accessories
