MoviePoster - Virtual movie poster display software. - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #1081 of 2322 Old 02-05-2015, 11:02 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Originally Posted by Colton View Post
Question.
I'm running the new 1.0.1.8. (Rev. 3) Movie Poster with Kodi. I have display #1 on the big screen showing trailers. Display #2 is going to two LED 50" TVs in the lobby. My question is: What is the best way for me to start Kodi and quietly shut down display #1 (keeping display #2 active to display the posters of the movie now showing)?
Keep up the great work!
you can right click on the poster area of the display you want to close and choose "Close" from the context menu. This won't exit the entire program and will leave the other display running. When you exit and reopen Movieposter the next time, both displays will still open. There isn't currently an automated way of closing a display, but it wouldn't be too hard to add an option for doing it from the webremote, eventghost or an http request.
Let me know if any of that sounds like what you are trying to accomplish.
meyer64 is offline
post #1082 of 2322 Old 02-05-2015, 05:54 PM
Colton's Avatar
@triplejs15: All from one computer. One HDMI connects to the motherboard (this handles the big screen movies) - the other HDMI connects to a PCIe video card that is connected to a HDMI splitter and goes to two 50" LED TVs (both showing the same thing, of course).
Meyer: Thanks for the tips. I'll try them out. I would be interested in finding a more automated solution that requires little of my involvement. Such as, if I launch KODI - the main MoviePoster display quietly closes automatically. I know very little about writing a script to make that happen. Come to think about it -- I'd have to close MoviePoster (main display) first to even launch KODI (to click on the icon). Maybe closing the main display, like you suggested, is the best option.
Thanks again.
Colton is offline
post #1083 of 2322 Old 02-06-2015, 10:00 AM
sraptor's Avatar
Meyer the sensor you created looks great. One thing I can recommend is btter to let the sensor outside so people can direct it in any position of the frame the will install. because will be hard if the sensor is inside that case. when rpi ver 2 is coming out will be great to install it inside the frame and will not required computer.
sraptor is offline
post #1084 of 2322 Old 02-06-2015, 12:26 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
It wouldn't be difficult to have an option for an external PIR sensor. It will cost a little more though. I'll see if I can fit a connector in the case somewhere to allow for one to be connected if desired.
meyer64 is offline
post #1085 of 2322 Old 02-06-2015, 06:04 PM
sraptor's Avatar
I did mine pir but your look better, maybe I will sell my movie poster and make another one bigger with one of your pir.
Will be so nice to have raspberry pi 2 with that software and everything in the same frame. I hope you will be able to port to that card or the one intel is releasing.
sraptor is offline
post #1086 of 2322 Old 02-08-2015, 06:26 AM
harrytasker1's Avatar
As long as there is no support for hardware decoding i think it will be difficult to have it run properly on a raspberry Pi 2.
I am building one now with a Intel Nuc Celeron, CPU is at around 80% and it peeks sometime at 100% when it's downloading and playing a trailer all at once.
With proper hardware decoding it would probably be easy to run on a RP2. For now the NUC will do for me
Keep up the good work on the PIR. Is it going to be one which you have to assemble yourself or can we buy a prebuild?
Format Neutral
harrytasker1 is offline
post #1087 of 2322 Old 02-08-2015, 07:24 AM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
I have made some performance improvements that help bring the cpu usage down a lot. My dev build now runs at about 3-4 % with spikes around 20% or so every now and then. Granted, that's on a Core i5 but it is a lot better than previous builds were. Still no hardware decoding though, sorry.
The motion sensor will be a prebuilt unit, ready for you to install. I assembled the protoype by hand with a proto board and jumper wires connecting the circuits, but I'm hoping there will be enough interest that I can justify ordering custom PCBs. they aren't really that expensive as long as I can order a large enough quantity.
harrytasker1 likes this.
meyer64 is offline
post #1088 of 2322 Old 02-08-2015, 07:49 AM
Nice!
Any idea when you will release a new build?
Any idea how a unit would cost approx.?
Format Neutral
post #1089 of 2322 Old 02-08-2015, 07:06 PM
sraptor's Avatar
I had installed in nuc i3 and work good.
sraptor is offline
post #1090 of 2322 Old 02-13-2015, 11:03 AM
rmilyard's Avatar
Quoted: 149 Post(s)
Any updates on PIR or software?
rmilyard is offline
post #1091 of 2322 Old 02-16-2015, 03:24 PM
rmilyard's Avatar
Quoted: 149 Post(s)
So I rebuilt my FreeNAS and HTPC over the 3 day weekend. Crazy week!
rmilyard is offline
post #1092 of 2322 Old 02-16-2015, 03:44 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Well, I have the prototype hardware working. I ended up adding some circuit protection and the option for an external sensor. While I was working on it, I decided that I really don't want to build too many of these things using proto boards. The assembly takes forever and the circuits were getting too complicated to build with jumper wires on such a small board. So I've been working on a PCB layout that I can have manufactured. I plan to have the layout finalized and an order placed for the first batch of boards in the next few days.
I still ave to write a utility for installing firmware updates though.
rmilyard, harrytasker1 and AXLCMT like this.
meyer64 is offline
post #1093 of 2322 Old 02-16-2015, 06:17 PM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
I cannot get it to display the movie currently being played. It shows connected on the bottom right, but no dice. Please help. Been beating my head against the wall for 20 minutes.
My Home Theater
smarcus3 is offline
post #1094 of 2322 Old 02-16-2015, 06:36 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Which version of MoviePoster are you using? What media software version? Plex? XBMC/Kodi?
meyer64 is offline
post #1095 of 2322 Old 02-16-2015, 06:41 PM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
MoviePower 1.0.1.6
XBMC Kodi 14.0
Have the connection ports as follows
IP 192.168.1.67
HTTP 8080
JSONRPC 9090
Webremote 9777
My Home Theater
smarcus3 is offline
post #1096 of 2322 Old 02-16-2015, 07:43 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
MoviePower 1.0.1.6
XBMC Kodi 14.0
IP 192.168.1.67
HTTP 8080
JSONRPC 9090
Webremote 9777
MoviePoster 1.0.1.6 was released long before Kodi 14 was available and isn't fully compatible. Please use MoviePoster 1.0.1.8 for compatibility with Kodi 14.
meyer64 is offline
post #1097 of 2322 Old 02-16-2015, 07:51 PM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
Works like a champ. Thanks.
My Home Theater
smarcus3 is offline
post #1098 of 2322 Old 02-17-2015, 06:12 AM
rmilyard's Avatar
Quoted: 149 Post(s)
WOW looking good! You are doing amazing work!
rmilyard is offline
post #1099 of 2322 Old 02-20-2015, 10:18 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Unfortunately, it looks like the poster download from theMovieDB.org is broken in all current releases of MoviePoster. I am implementing a fix and will post an updated build soon.
meyer64 is offline
post #1100 of 2322 Old 02-21-2015, 05:53 AM
rmilyard's Avatar
Quoted: 149 Post(s)
Really? I didn't notice yet. Been busy with honey do stuff.
rmilyard is offline
post #1101 of 2322 Old 02-21-2015, 08:26 PM
rmilyard's Avatar
Quoted: 149 Post(s)
So something change at the source then?
rmilyard is offline
post #1102 of 2322 Old 02-21-2015, 08:34 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Yeah, the base url for the images changed and I didn't handle that in my code. I've now implemented retrieving the base url dynamically, so it shouldn't be an issue in the future. Just need to tie up a few other loose ends and I'll post a new build.
meyer64 is offline
post #1103 of 2322 Old 02-22-2015, 01:33 AM
My MoviePoster frame is almost ready, will post some pics when i am done.
Anyway when i started testing today i noticed sometimes a poster gets stuck it, it doesn't continue.
It's always a poster with a video. They used to work fine before (i mean last week) and now the poster shows but the video screen stays black, no video playing.
When i use the remote.html i can skip to the next poster though.
Any idea what goes wrong?
Format Neutral
post #1104 of 2322 Old 02-22-2015, 10:55 AM
djlf's Avatar
Liked: 0
will mediabrowser plugin be in next update?? please say YES!!
djlf is offline
post #1105 of 2322 Old 02-22-2015, 12:11 PM - Thread Starter
meyer64's Avatar
Quoted: 289 Post(s)
Liked: 241
Not off hand. Can you send me a log file?
meyer64 is offline
post #1106 of 2322 Old 02-22-2015, 12:19 PM
fibertech's Avatar
https://www.dropbox.com/sc/wdev2v3os...XRV2fvK23J7bva
https://www.dropbox.com/sc/y65tivqpo...mpnRM99QlFanTa
https://www.dropbox.com/sc/bjusbva1q...NOG263MOBET9Ba
I can't get these pics to show up in here. I will just add the links until I figure this out.
rmilyard likes this.
fibertech is offline
post #1107 of 2322 Old 02-22-2015, 07:10 PM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
Looking forward to the fix. However, great software. Love it.
I am a programmer myself and reasons like this is why I hate grabbing data from websites which you don't own. Anytime they change structures, URLs, etc. it breaks your code.
My Home Theater
smarcus3 is offline
post #1108 of 2322 Old 02-22-2015, 08:14 PM
MarsRup's Avatar
Played around a few days ago and got it working on my spare 19" LCD monitor.
Installed in my in-progress basement.
Thanks for putting the app out there for us!
MarsRup is offline
post #1109 of 2322 Old 02-23-2015, 07:40 PM
me23's Avatar
Quoted: 14 Post(s)
Hey meyer, finally got around to installing the .8 alpha and I cant figure out how to set the xbmc settings. Under connection options there is just a blank box and checkboxes for webremote, show connection status and enable log. .7 preview showed xbmc settings like ip address, etc., but I don't see anything for this.
me23 is offline
post #1110 of 2322 Old 02-23-2015, 08:42 PM
MarsRup's Avatar
I had the same thing. Thought maybe it was just me.
MarsRup is offline
Reply Theater Room Items & Accessories
