MoviePoster - Virtual movie poster display software. - Page 41 - AVS | Home Theater Discussions And Reviews
Old 03-30-2015, 06:44 PM
the_abbot's Avatar
Quoted: 139 Post(s)
Will we be seeing a new release this week?
the_abbot is offline
Old 03-31-2015, 09:43 AM
loma's Avatar
Quoted: 13 Post(s)
Motionposters
@Meyer
Tried playing motionposters version 2.0. The poster shows only half in a different aspect ratio. Any adjustments I can make?
loma is online now
Old 03-31-2015, 11:21 AM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
Originally Posted by loma View Post
@Meyer
if is a motionposter in a video file format like mp4, its likely a problem with the new mplayer version. if you really want to mess around with it, you can copy the mplayer folder from one of the previous versions to the new install.
meyer64 is online now
Old 03-31-2015, 01:40 PM
loma's Avatar
Quoted: 13 Post(s)
Thanks. That fixed it.
loma is online now
Old 04-06-2015, 04:00 AM
harrytasker1's Avatar
Quoted: 12 Post(s)
Site has been down for a couple of days? Are you moving hosting?
Format Neutral
harrytasker1 is offline
Old 04-06-2015, 10:13 AM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
Well, I wasn't planning on moving to a new host. But the reliability of my current one is getting worse all the time. So as of today, I guess I am working on switching to a new hosting provider. Sorry for the inconvenience.
harrytasker1 likes this.
Old 04-06-2015, 05:54 PM
sraptor's Avatar
new intel stick
meyer how will work this stick with your software?
http://www.newegg.com/Product/Produc...B&gclsrc=aw.ds
sraptor is online now
Old 04-07-2015, 11:25 AM
ConradC's Avatar
Quoted: 40 Post(s)
Liked: 61
It would work just like any other computer using MoviePoster. The only difference would be the size and power requirements (powered by usb). Oh and maybe the network connection type since this is WiFi only.
ConradC is offline
Old 04-08-2015, 07:29 PM
Barrettmr's Avatar
Quoted: 90 Post(s)
Liked: 25
Just downloaded and tried this new version, been waiting for integration with MediaBrowser3 and its looking good! Quick question - when I quickly tested it tonight (only spent a few minutes on it) the MB3 integration worked great when I started a film but the image was not the movie poster but rather the box art with treatments from MB3, do I need to add a real poster image in the movies folders or should the app grab a poster from online?
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
Old 04-08-2015, 07:41 PM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
It uses the mediabrowser art as a fallback if for whatever reason it cant find the poster online or in the cache. The MB3 integration is pretty new, so theres always the possibility that its falling back to the mb3 art, even when it shouldn't. I'll take a look at it.
Old 04-08-2015, 07:45 PM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
The website is now at a new host. It should be available in the next day or so as DNS gets updated.
Old 04-09-2015, 11:14 AM
the_abbot's Avatar
Quoted: 139 Post(s)
Sweet. Will there be a version 2.1 uploaded in the near future?
Old 04-09-2015, 11:41 AM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
Yes, a new version is nearly ready. I just need to test a bit more. It includes several bug fixes. along with the following enhancements:
Ability to configure/enable/disable plugins using the web remote.
Ability to select trivia to be displayed from a list of available folders (Trivia Library).
Fix for trailer streaming.
Ability to display a webpage as a poster (Experimental, works really well for showing live game scores from ESPN)
Old 04-14-2015, 11:11 AM
agent62's Avatar
problems with 2.0
i am a registered user. had no issues with 1.7. but with 2.0 it opened and carried over my registration then crashed. now it will not open.
here's the event log:
Faulting application name: MoviePoster.exe, version: 2.0.0.0, time stamp: 0x5504eb33
Faulting module name: KERNELBASE.dll, version: 6.3.9600.17278, time stamp: 0x53eeb460
Exception code: 0xe0434352
Fault offset: 0x00012f71
Faulting process id: 0xec8
Faulting application start time: 0x01d076ddb6566879
Faulting application path: C:\Program Files (x86)\Great Dane Cinema\MoviePoster\MoviePoster.exe
Faulting module path: C:\WINDOWS\SYSTEM32\KERNELBASE.dll
Report Id: f48ada5b-e2d0-11e4-83f3-c89cdcd2c866
Faulting package full name:
i tried .net repair to no avail.
thanks for your help.
agent62 is offline
Old 04-14-2015, 11:21 AM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
Which OS are you using?
Does the same error occur if you try running it under another user account?
Old 04-14-2015, 11:31 AM
agent62's Avatar
windows 8.1 - Ive only tried with my main administrator account
agent62 is offline
Old 04-18-2015, 09:58 AM
agent62's Avatar
Hey Meyer,
yes it did install and run fine from another account.
what can i do to get it running on my main account?
thanks alot
agent62 is offline
Old 04-18-2015, 10:17 AM - Thread Starter
meyer64's Avatar
Quoted: 66 Post(s)
Liked: 97
Hey Meyer,
thanks alot
I suspect something got corrupted in the settings somehow. You can delete all current settings by removing the MoviePoster folder from the AppData\Local folder. example: C:\Users\meyer\AppData\Local\MoviePoster
Appdata is hidden so you'll have to turn on view hidden files.
That will wipe out any settings that could be causing the problem. The files will be regenerated the next time you run the program from that user account.
Old 04-18-2015, 11:19 AM
agent62's Avatar
meyer,
deleted local appdata folder. opened fine, maximized fine, select settings then it crashed.
here is the last log:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-04-18T18:13:06.000000000Z" />
<EventRecordID>3285056</EventRecordID>
<Channel>Application</Channel>
<Computer>TheHutTheater</Computer>
<Security />
</System>
- <EventData>
<Data>MoviePoster.exe</Data>
<Data>2.0.0.0</Data>
<Data>5504eb33</Data>
<Data>KERNELBASE.dll</Data>
<Data>6.3.9600.17278</Data>
<Data>53eeb460</Data>
<Data>e0434352</Data>
<Data>00012f71</Data>
<Data>458</Data>
<Data>01d07a0331c6da9f</Data>
<Data>C:\Program Files (x86)\Great Dane Cinema\MoviePoster\MoviePoster.exe</Data>
<Data>C:\WINDOWS\SYSTEM32\KERNELBASE.dll</Data>
<Data>8f73984f-e5f6-11e4-83fc-4c60dee48dbd</Data>
<Data />
<Data />
</EventData>
</Event
thanks again for your help
agent62 is offline
Old Today, 08:38 AM
loma's Avatar
Quoted: 13 Post(s)
loma is online now
Old Today, 08:38 AM
loma's Avatar
Quoted: 13 Post(s)
loma is online now
