MoviePoster - Virtual movie poster display software. - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 231Likes
Old 06-01-2015, 10:26 PM
krh1009's Avatar
The Plex plug-in for Now Showing had been working fine. I just recently updated the Plex server to : 0.9.12.1 and the Now Showing stopped working. I looked at the log and it only shows that the plug-in is connected to the server:
Code:
6/1/2015 10:13:56 PM - temp Pause Off
6/1/2015 10:13:58 PM - Plugin Connection Status Changed: PLEX Server on mediaserv : True
6/1/2015 10:14:16 PM - Show Next
Is there a way to turn on debugging in the Plex plug-in ?
krh1009 is offline
Old 06-02-2015, 08:40 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
Code:
Unfortunately no, there isn't any further debugging / logging option for the plugins. I will look into the issue though.
meyer64 is offline
Old 06-02-2015, 08:41 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
Originally Posted by rmilyard View Post
@meyer64 Are you seeing this issue also?
Other users have reported this issue and it will be addressed in a future release.
meyer64 is offline
Old 06-02-2015, 08:45 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
For those interested, more information regarding the Motion Controller, including a draft of the user guide is now available on movieposterapp.com
This link will take you right to the product page:
http://movieposterapp.com/products.html
meyer64 is offline
Old 06-02-2015, 09:42 PM
AVMax's Avatar
Code:
I'm running Plex Media Server version: 0.9.12.1.1079-b655370 on a Mac -Mini and the Now Playing feature is still working correctly. Movie Poster is running on an older Compaq with Windows Vista.
AVMax is offline
Old 06-03-2015, 03:27 PM
krh1009's Avatar
Code:
OK I've changed the plug-in to point to the "Kitchen" Roku player instead of the "Media Room" Roku player. The plugin in switched to the Now Playing screen, start and end times are displayed, but the poster area is blank. From the log:
Code:
6/3/2015 5:07:32 PM - temp Pause Off
6/3/2015 5:07:32 PM - Error Retrieving data from Rotten Tomatoes: The remote server returned an error: (403) Forbidden.
6/3/2015 5:07:32 PM - Saving ExtraArt for tt2381941.
6/3/2015 5:07:33 PM - Error in GetBipmapFromImage
6/3/2015 5:07:33 PM - Now Playing:
6/3/2015 5:07:33 PM - Error Retrieving data from Rotten Tomatoes: Object reference not set to an instance of an object.
6/3/2015 5:07:34 PM - Error Applying default flags: Object reference not set to an instance of an object.
6/3/2015 5:07:34 PM - Updating UI started for
6/3/2015 5:07:34 PM - Error updateing plugin display NEW METHOD - Object reference not set to an instance of an object.
6/3/2015 5:07:34 PM - Using Transition Effect: Fade
6/3/2015 5:07:34 PM - Updating UI Finished
6/3/2015 5:07:34 PM - temp Pause Off
I've attached the full log
krh1009 is offline
Old 06-05-2015, 02:24 PM
MarsRup's Avatar
Got a little tech support question here. I've gotten the Movieposter App working perfectly on my main workstation PC (as seen in my build thread: MarsRup's homage to a forgotten theater. ), but when I try to run it on my HTPC, it crashes when the app starts up.
On a completely fresh, fully updated install of Windows 7, the app starts normally but then crashes shortly after. After that, it crashes every time I start the app. Here's a screenshot of the error dialog box I get:
Any idea where I should start poking it? Has there been any problems running the app on the same PC as XBMC?
MarsRup is offline
Old 06-06-2015, 08:01 PM
krh1009's Avatar
I'm still having the problem where the plex plug-in will not display the poster image for NOW SHOWING, just the start, end times and the movie tag-line at the bottom.
ANY suggestions for a fix?
krh1009 is offline
Old 06-06-2015, 08:26 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
Do you see any consistency in which posters show and which don't?
If you stop the movie and play the same one again, is the result the same?
meyer64 is offline
Old 06-06-2015, 08:31 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
There shouldnt be a problem running MoviePoster on the same machine as XBMC.
First make sure you have the .Net framework version 4.5 installed.
If you still get the error send me a copy of the displayconfig.xml file found in the AppData folder. for example C:\Users\meyer\AppData\Local\MoviePoster\System
I have a suspicion of what the problem could be. I'm still not sure of the root cause, but I might have a fix in place in for 2.1 If you'd like to be a guinea pig and test it out, just let me know and I'll send you instructions.
meyer64 is offline
Old 06-06-2015, 10:27 PM
krh1009's Avatar
So far I've only found one movie that displays when in the "Now Showing" mode. Stopping and starting does not help. I've also verified the movies that don't display when "Now Showing" have been downloaded and in cache, since they display in the random "Coming Soon" mode.
From the log when nothing is shown:
Code:
6/6/2015 8:55:16 PM - Now Playing:
6/6/2015 8:55:16 PM - Error Retrieving data from Rotten Tomatoes: Object reference not set to an instance of an object.
6/6/2015 8:55:17 PM - Error in GetBipmapFromImage
6/6/2015 8:55:17 PM - Error Applying default flags: Object reference not set to an instance of an object.
6/6/2015 8:55:17 PM - Updating UI started for
6/6/2015 8:55:17 PM - Error updateing plugin display NEW METHOD - Object reference not set to an instance of an object.
From the log when it is working:
Code:
6/6/2015 8:54:18 PM - Sex Tape - tt1956620 - has been loaded from the cache.
6/6/2015 8:54:19 PM - Now Playing: Sex Tape
6/6/2015 8:54:20 PM - Updating UI started for Sex Tape
6/6/2015 8:54:20 PM - Using Transition Effect: Blood
6/6/2015 8:54:20 PM - Updating UI Finished
krh1009 is offline
Old 06-07-2015, 12:33 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
@krh1009 Which version of movieposter are you running?
meyer64 is offline
Old 06-07-2015, 10:34 AM
krh1009's Avatar
I thought it was 2.0...but just to make sure I uninstalled (and move the movie poster folder in app data). Download the version from the website and re-installed. Now I'm back to the case where it doesn't switch to the Now Showing screen.
From the log
Code:
6/7/2015 12:26:59 PM - Starting MoviePoster Version 2.0.0.0 ...........
6/7/2015 12:26:59 PM - Initializing displays
6/7/2015 12:26:59 PM - Init Portrait Layout
Code:
6/7/2015 12:27:01 PM - Now Playing movie count: 20
6/7/2015 12:27:03 PM - There was an error in the posterDisplayObject/tmdbmovie Constructor. -Object reference not set to an instance of an object.
6/7/2015 12:27:03 PM - Error getting poster - /fWOPN0XBvHXFYr3RsPr74qBge2I.jpg
6/7/2015 12:27:03 PM - Error saving tt1029360-Poltergeistto the cache. - Operation is not valid due to the current state of the object.
6/7/2015 12:27:03 PM - Error getting NowPlaying movies Object reference not set to an instance of an object.
6/7/2015 12:27:03 PM - retrieved tmdb movie list:
krh1009 is offline
Old 06-07-2015, 11:03 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
From the log
Code:
Code:
It looks lie its having trouble downloading the posters for some reason. There was a known issue in previous versions that should have been fixed in 2.0. For any that are already saved in the cache it should work fine, but obviously that isn't really a solution. Are you noticing any other posters that fail to download?
meyer64 is offline
Old 06-09-2015, 04:59 PM
krh1009's Avatar
I haven't noticed any other problems.
krh1009 is offline
Old 06-09-2015, 07:10 PM
MarsRup's Avatar
Thanks so much for the response! It indeed has .Net 4.5 installed. Here's the xml file: http://rupelli.com/dump/displayconfig.xml
MarsRup is offline
Old 06-09-2015, 07:37 PM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
As I suspected. one of the window size parameters somehow got saved as a non integer value.
<height>729.333333333333</height>
if you were to change that to a whole number instead of a decimal, the program should run fine. I dont know under which conditions this happens, since it doesnt happen for everyone but has been reported on multiple operating systems. It could be windows DPI settings, graphics drivers, i really dont know. However, I do account for this in my dev build, which I plan to have ready for release soon. If you'd like to try it out in advance, I'll pack it up for you.
meyer64 is offline
Old 06-09-2015, 09:04 PM
MarsRup's Avatar
That's definitely the problem. I fixed the one line in the XML file and the app started fine. But then, as soon as I hit 'settings', it crashed again. Then I looked at the XML file and all the other pixel settings had that 1/3 pixel rounding error.
MarsRup is offline
Old 06-10-2015, 08:46 AM
MarsRup's Avatar
This might be something you already know about, but I turned off scaling and it seems to work. Out of three PCs (living room HTPC, basement HTPC and workstation), the app only ran on my workstation which doesn't have scaling enabled.
Might do some experimenting on settings and stuff here.
MarsRup is offline
Old 06-15-2015, 10:02 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Has anyone been able to get the trailers window to size correctly? Mine shows up as a small box onscreen.
the_abbot is offline
Old 06-15-2015, 10:12 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
Can you send me a screenshot?
meyer64 is offline
Old 06-15-2015, 11:01 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
This is how my trailers show up.
Old 06-15-2015, 11:08 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
thats a glitch in the screen rotation. The problem is caused by an issue with the included version of mPlayer.
There are two things you can do to fix it.
1. use Windows screen rotation (set to portrait) instead of the rotation built into MoviePoster.
2. Copy the mplayer directory from a previous version of MoviePoster into the 2.0 installation directory, replacing that version.
This issue is fixed for the next release, which is expected to be released the first week of July.
meyer64 is offline
Old 06-16-2015, 10:26 PM
krh1009's Avatar
OK...I fixed this problem. It appears there was an issue with my Plex Movie library. I created a new library and add all the same movies to the new library. The now showing images appear fine.
krh1009 is offline
Old 06-16-2015, 10:31 PM
krh1009's Avatar
Question: The number of cached poster seam to stay around 85, even though I have changed the min number of images to 700 (15 days to keep). Is there a way of forcing more posters to be downloaded?
I also pushed the download new poster button on the remote, a gear icon appears, but no new posters in the cache. (not sure of the purpose of this button).
krh1009 is offline
Old 06-17-2015, 06:36 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
Try increasing the Max Page counts on the TMDB Options tab. Each page is about 20 posters. But if a poster is in more than one of the categories it will only be downloaded once. If you haven't already, also take a look at the Filters tab. this restricts the genres and ratings of posters you want to see. Anything that doesn't meet your filter criteria, will not be downloaded or shown.
The Download New Posters button in the webremote forces the download process to start. Normally, this process runs after each 'loop' of posters has been shown. The button just runs it on demand, but it still functions within the limits of your filters and TMDB category options.
meyer64 is offline
Old 06-18-2015, 10:07 AM - Thread Starter
meyer64's Avatar
Quoted: 279 Post(s)
Liked: 231
I'd like to do a bit of performance analysis of the different hardware everyone is running MoviePoster on.
If you happen to have some free time, I'd really appreciate some input on the below survey.
https://docs.google.com/forms/d/170B...?usp=send_form
meyer64 is offline
Old 06-18-2015, 10:17 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Done
Old 06-20-2015, 04:09 AM
harrytasker1's Avatar
Done!
Format Neutral
harrytasker1 is offline
Old 06-20-2015, 08:02 AM
rmilyard's Avatar
Quoted: 129 Post(s)
Done. However is there a 2.1? I thought 2.0 was latest version.
rmilyard is offline
