MoviePoster - Virtual movie poster display software. - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 231Likes
Old 03-20-2013, 09:05 AM
dukedallas2005's Avatar
Ok no problem... I can live with the current method of double-clicking on the screen to close, I'm not sure of this whole web remote control thing, I currently connect using RDP to my HTPC using a Andriod tablet so there is no easy right click. I'll mess around with Trivia folder and see how it goes. All my digital photos are organized by dirctory & folder structure of Year / Month on my hard drive so I can just manually change the folder on occasion. Which is better than nothing. Im going to look for a motion activated 12v trigger online and see if they exist today so the tv comes on when someone walks by it like you have done.
dukedallas2005 is offline
Old 03-20-2013, 09:27 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
The trick to having a motion sensor turn the tv on is knowing if it's already on, so it doesn't continually switch on and off when it detects motion. Make sure you account for that. My motion sensor setup is working flawlessly for me and was around $30 worth of parts. It wasn't all that hard to put together and is mostly off the shelf components. Just had to do a little soldering and coding for the teensy usb board.
meyer64 is offline
Old 03-20-2013, 11:35 AM
Yeah I was just looking to rig something off the shelf type, no way am i electronically inclined using board connectors etc. LOL!
BTW How did you make the Great Dane Marquie Page...What font or program is that?
I'd like to set up my theater Name in that same gold font for my start page.
Old 03-20-2013, 11:51 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
I used paint.Net to make the Great Dane Cinema logo. Its a modified version of a desktop wallpaper I made for my HTPC. Unfortunately I cant find my original files for it at the moment. But I've attached the most recent .pdn file I could find. Hopefully it will be usefully in creating your own. The text isnt just a font, rather a layer with the text cut out of it, over a layer containing the gold gradient. The reflection of the text is also composed of multiple layers to achieve the desired effect. Poke around in the .pdn file and turn the layers on and off and you'll get the idea.
Great Dane Cinema reflection Poster small.zip 222k .zip file
File Type: zip Great Dane Cinema reflection Poster small.zip (221.7 KB, 85 views)
meyer64 is offline
Old 03-20-2013, 12:03 PM
You Sir by far are the BEST humaniod on this planet ...Thank you! biggrin.gif
Old 03-20-2013, 12:23 PM
loma's Avatar
Quoted: 21 Post(s)
Originally Posted by loma View Post
I have set up as indicated above and can get access from another computer. However I wish to open MoviePoster with EventGhost web page. Can you help with an example of the path (mapped drive) to use to be able to access MoviePoster?
Hi meyer, I think you missed my previous post as above. Can you help?
loma is offline
Old 03-20-2013, 12:34 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
I couldnt find my working files that still contained the separate layers for making the reflected text, so i put together a quick example file. I think the font I used was Garamond. reflected text example.zip 71k .zip file
meyer64 is offline
Old 03-20-2013, 12:40 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
in the 'Start Application' Action Item you have set up to launch MoviePoster you should be able to just change the executable path to point to the location on the network share. if you have a network share mapped as a drive it could look like: X:\movieposter\movieposter.exe
or using a unc path: \\sharename\movieposter.exe
the exact path names will be different based on your exact setup.
meyer64 is offline
Old 03-20-2013, 08:04 PM
0blar's Avatar
Hello
Thanks for your works
I just want to know where can we download the latest version of the software
The latest I found on http://sourceforge.net/projects/xbmcposterdisp/ is 1.0.1.5 , is it the latest ?
Regards
0blar is offline
Old 03-20-2013, 08:09 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
Yes. That is the latest release. I'm currently working on adding new features and will release the next version when complete.
meyer64 is offline
Old 03-20-2013, 10:03 PM
loma's Avatar
Quoted: 21 Post(s)
Thanks for your response. I will review to see if this approach will achieve what I am trying to do..
loma is offline
Old 03-23-2013, 08:35 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Wow- What an awesome thread .
Mfusick is offline
Old 03-27-2013, 10:46 AM
Colton's Avatar
Is there an option to turn off the "Coming Soon"?
Colton is offline
Old 03-27-2013, 10:57 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
Not currently, but I plan to include support for custom banners in the next release. You could easily make a blank one, or substitute whatever image you prefer.
meyer64 is offline
Old 03-27-2013, 11:08 AM
Colton's Avatar
Thanks, meyer64 ... excellent program. This will replace two of my lightboxes. I'm going to buy a dedicated ZOTAC PC to run Windows 7 and MoviePoster, but how will I split the HDMI cable to go to two different TVs? Is there a better way of doing this?
Just tested the trailer option and when it tries to play it gives me an error: mplayer - no disk ...
"There is no disk in the drive. Please insert a disk into drive \Device\Harddisk1\DR1."
-Colton
Colton is offline
Old 03-27-2013, 08:19 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
Whoa. That's wired...... Does that happen for any trailer you try to play? Did you change any settings? Or did you happen to have mplayer already installed separately?
meyer64 is offline
Old 03-27-2013, 08:28 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
A quick google search reveals that the error can be caused by the mplayer working directory being on a drive with removable media like a cd drive or sd card read that doesn't currently have a disk mounted. One Post found suggests changing the drive letters of cd drives and card readers. It's worth a shot I guess.
meyer64 is offline
Old 03-28-2013, 06:37 AM
Colton's Avatar
Thanks again, meyer64. I do have a WD Passport connected (USB). I'll disconnect it and try again.
What computer system do you recommend to run MoviePoster? I'm looking for something very small for my home theater. I'll use a HDMI splitter to send the MoviePoster to two 42" LCD TVs.
Colton is offline
Old 03-28-2013, 06:47 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
it doesnt need to be a very powerful computer. I run mine on an Nvidia Ion system with an Atom 330 and 2gb ram. Any of the Zotac systems would be plenty good enough. If it can run Win7 reasonably, it will be enough for MoviePoster. The only thing i can really see being an issue on very slow hardware would be HD trailer playback. Personally i dont see the point in playing any trailers over 720p though since the trailer playback area doesn't fill the screen anyway.
The only problem I have run into with my setup is that I only have a 32GB SSD installed. My internet connection is fairly slow, so I have MoviePoster set to download the trailers automatically instead of streaming them, which starts to fill up the drive. I'll be upgrading to a larger drive as soon as I get around to it.
meyer64 is offline
Old 03-28-2013, 08:09 AM
Mopar_Mudder's Avatar
Quoted: 25 Post(s)
Liked: 32
Just wondering why you would want to split the HDMI to two different displays? You are going to have the same thing showing on both then? I can see having two displays and having different posters display on each one, you would have to run something like a dual monitor setup
Mopar_Mudder is offline
Old 03-28-2013, 03:02 PM
Colton's Avatar
True. It will show the same posters on both sides of my theater. My home theater room configuration has a ticket booth in the middle and a poster lightbox on each side. I want to replace the lightboxes with vertical 42" LCD TVs, but to run different posters on each would require a dedicated computer for each. I *may* do that down the road, but for now both LCDs will show the same poster.
The other option is finding a good 42" LCD TV that has a decent slideshow feature and simply put movie poster images on a small USB key and have each TV display different posters. This eliminates having to buy a dedicated PC for each.
Colton is offline
Old 03-28-2013, 03:46 PM
Quoted: 25 Post(s)
Liked: 32
Is it possible to run two instances of virtual movie poster at the same time on one computer set-up with dual displays. That way you can run a seperate cable to each screen in dual display mode, as long as the compter supports it.
Old 03-28-2013, 03:53 PM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
You could run two displays off one pc. Nearly all modern video cards support multiple displays. MoviePoster doesn't do anything to stop multiple instances from running on the same PC either, but the config file is currently stored in your user directory so all settings between the two instances would be identical, including window position. If you want to pursue running two instances on one PC, it shouldn't be too hard for me to make changes to support that usage scenario. You could also try running one of the instances using a 'runas' command to force that instance to run under a different user account and therefore have its own settings and window position. If you do this, make sure to set different port numbers for the web remote for each instance or they will conflict. You could have separate audio outputs for each instance configures in the settings too. It should work, but I haven't tested it.
meyer64 is offline
Old 03-28-2013, 04:04 PM
Quoted: 25 Post(s)
Liked: 32
You sure make it hard to resist buying TV's to do this, glad it doesn't work on Media Browser as of right now or I would be spending money.................really need a couple of 42" touch screens cool.gif
Old 03-28-2013, 05:04 PM
Colton's Avatar
Oh, yes!! Please support multi-displays! That would be so awesome!
Colton is offline
Old 03-30-2013, 09:12 AM
loma's Avatar
Quoted: 21 Post(s)
Hi meyer, how are the updates coming along?
loma is offline
Old 03-30-2013, 09:18 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
Slow and steady. I've been pretty busy with other things lately, but i do have the code a bit more modular to make it easier to support other media players.
I have been in contact with the folks over at MediaBrowser and have been given access to their Dev Forum. Unfortunately, I haven't had time to set up a test environment for MB3 yet.
meyer64 is offline
Old 03-30-2013, 09:28 AM
loma's Avatar
Quoted: 21 Post(s)
Great. I did see your post at MB and really look forward to your input there. By the way, will Remote have a close button so that one can close the remote only not MoviePoster?
loma is offline
Old 03-30-2013, 11:11 AM
tranced's Avatar
Thank you soo much for this amazing software. I have been using it for over 2 months and it has been great!
I had two feature requests if possible.
1) Can you allow animated gif files to be used for motion posters.
2) Can we have a custom folder for our own images/posters. I was hosting a super bowl party and would have loved to put in a poster to be displayed for the upcoming game. Also occasionally I would like my family photos displayed ( i know it defeats the purpose of a Movie poster" but it would make the application fit greater needs.
Thanks !
tranced is offline
Old 03-31-2013, 08:55 AM - Thread Starter
meyer64's Avatar
Quoted: 281 Post(s)
Liked: 231
loma, yes the ability to close the application as well as shutdown/ reboot the pc from the web remote will be included in the next release.
Tranced, animated gif support for motion posters is on my list of features to add, I haven't gotten to it yet, but it should be in the next release. It will be pretty easy to add support for just displaying a folder full of pictures or custom posters too.
meyer64 is offline
