looking for very specific movie sign light bulbs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-28-2012, 10:49 PM - Thread Starter
boxeldermo's Avatar
so when i was 17 i worked at blockbuster video and one night they were throwing out a big movie poster display box so i took it home. for the last 13 or so years it's been sitting up in my parents' attic until i took it home today. i want to fix it up, but there are these little light bulbs that i can't figure out how/where to buy. like 9/10ths of them are burned out, so no matter what else i do it's not gonna look nice unless i replace them. the box itself was probably made specifically for blockbuster and there's no distinguishing markings on there (manufacturer etc). the bulbs only say "forelite 12" on them, but google has given me nothing on that, even searching specialty light bulb sites. i've also tried to google variants of "blockbuster movie lightbox" just to get more info, but have found nothing on that either. so like, what can i do to find/buy some of these bulbs? here's a picture for reference (i'm talking about those little lights that surround the poster, not the back lighting):
if anyone has any clue where i can go from here, i'd appreciate it. and yes all the posters i had were also from when i was in high school so it's all horror movies
boxeldermo is offline
post #2 of 12 Old 12-29-2012, 02:19 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
They're probably commonly available bayonet bulbs. Take one out and post a picture of it. Then check 1000bulbs.com and see if they've got it...
jautor is offline
post #3 of 12 Old 12-29-2012, 08:33 PM - Thread Starter
boxeldermo's Avatar
here's a picture (with a dime for scale):
i don't see anything on that site that looks like this. they're some kind of wire base bulbs, with two little exposed wires on the bottom to complete the circuit (like most christmas lights, but smaller and a different shape)
post #4 of 12 Old 12-29-2012, 09:00 PM - Thread Starter
boxeldermo's Avatar
and i mean i don't need to find the exact same bulbs. if i could find something that would work and also look ok i would just replace all of them. and i also don't expect anyone to just find me exactly what i'm looking for (though that would be sweet!), but just to kind of point me in the right direction of how i could possibly find something
post #5 of 12 Old 12-30-2012, 02:51 PM
jautor's Avatar
Liked: 777
Ok, well, you stumped me... Never seen one like that!!! You might try emailing that image to some bulb sellers to see if they can identify it.
And that's one piece, correct? The bulb doesn't come out of that plastic assembly?
jautor is offline
post #6 of 12 Old 12-30-2012, 04:04 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
It may be helpful to know if these lamps are 120v or a low voltage lamp. Measure the voltage with a VOM or if you can remove the back and follow the wiring to see if there is a step down transformer in the circuit.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #7 of 12 Old 12-30-2012, 04:15 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
How about this
http://www.bulbtown.com/LM1012WB_W_LED_MINIATURE_BULB_WEDGE_BASE_p/lm1012wb-w.htm
Doug
post #8 of 12 Old 12-30-2012, 11:04 PM - Thread Starter
boxeldermo's Avatar
that's definitely the closest i've seen and actually looks like it might work, but it's impossible to tell from that photo. like, the picture looks like that one might flatten out at the bottom (like many similar Christmas bulb lights do) and the one i'm looking for has a round bottom. but maybe i can contact the seller and get more info, because like i said it does look like it might work and that's better than anything i've found so far. thanks
post #9 of 12 Old 12-31-2012, 12:49 AM
jautor's Avatar
Liked: 777
eek.gifeek.gif But at $13 each (times ~88 lamps) if that LED replacement is your only option you should just buy a nice new frame from Stargate...
jautor is offline
post #10 of 12 Old 12-31-2012, 11:07 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
You still have to figure out what voltage is being sent to the lamps .. that is a 12v, what's the voltage your sign is delivering to the lamps?
Doug
post #11 of 12 Old 12-31-2012, 09:33 PM - Thread Starter
boxeldermo's Avatar
i assume it's 12v because the bulbs say "forelite 12" on them
post #12 of 12 Old 12-31-2012, 10:24 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Would be a reasonable guess but a VOM would be more exact and safer
Doug
Reply Theater Room Items & Accessories
