Squeaky Theater Chairs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-30-2012, 08:34 PM - Thread Starter
Jawhn's Avatar
I recently purchased 2 Lane Matinee/Berkline Reno chairs. They are powered, bounded leather, in a loveseat configuration. I love the chairs, but the leather squeaks when reclining and it's a bit irritating (especially during a quiet movie). Anyone else have this problem? Will using a leather conditioner help? Any other suggestions?
Jawhn
If the Theater is a Rockin, don't come a Knocking!
My Home Theater
Jawhn is offline
post #2 of 7 Old 12-31-2012, 07:32 AM
KenLerch's Avatar
Liked: 29
Easy fix: Put a little bit of talcum powder between the seat and the arm where the leather is rubbing. The noise will go away instantly.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #3 of 7 Old 01-07-2013, 10:52 AM - Thread Starter
Jawhn's Avatar
Thanks Ken, worked perfectly.
Jawhn
My Home Theater
Jawhn is offline
post #4 of 7 Old 01-07-2013, 05:39 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi Ken, is this liquid powder and a clear substance? This is a good idea but don't want white powder showing on the chairs. Have a link where I can by this? Thanks.
JChin is offline
post #5 of 7 Old 01-07-2013, 05:48 PM
KenLerch's Avatar
Liked: 29
jchin,
Talcum powder is the same thing as baby powder that you can buy in any grocery store for a few bucks. smile.gif Just put a small amount between the seat and the arm where the friction occurs and wipe up the excess with a damp paper towel. It can be a little messy at first but it's a quick fix.
Ken Lerch
StargateCinema.com
HTSeating.com
KenLerch is offline
post #6 of 7 Old 01-07-2013, 06:14 PM
rsh
rsh's Avatar
Quoted: 94 Post(s)
Liked: 55
You can also try paraffin wax
Roman
rtheaters.com
FusionCollectionSeating.com
Ultimate Home Entertainment
rsh is online now
post #7 of 7 Old 01-08-2013, 08:44 AM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Will try one of these remedies, thanks Ken and Roman.
JChin is offline
Reply Theater Room Items & Accessories
