Blacking out Windows - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2013, 08:29 PM - Thread Starter
jcisbig's Avatar
Quoted: 71 Post(s)
Liked: 47
Hey All,
Has anyone tried this product?
http://www.blackoutez.com/
Is there a better option out there for the cost? I have two large windows (95 inches wide x 50" tall), and the cost would be about $75 for each window.
Dedicated Theater Room: Aperion Verus Grand Towers and Center, Aperion Intimus 4BP Surrounds, Dual JTR Cap 1400s, Emotiva UMC-200 Processor, Emotiva XPA-2 and UPA-7
Epson 5030UB Projector, 100" Elite Saker Tab Tension Acoustically Transparent Screen, HT Design Southampton Seats, DIY Bass Traps and Acoustic Panels
Office: Emotiva Airmotiv 6S Monitors, Aperion 8D Subwoofer, Emotiva DC-1 DAC, Emotiva Control Freak (Balanced)
jcisbig is offline
post #2 of 3 Old 02-05-2013, 07:32 PM
riverwolf's Avatar
Liked: 24
Easy DIY project. It's just blackout cloth and adhesive backed velcro. Similar cloth sells for about $15/yard (54" wide) at your nearest fabric store.
-Brent
riverwolf is offline
post #3 of 3 Old 02-07-2013, 01:20 PM
Rob Greer's Avatar
I took sheets of 4x8 foamcore and used a carpet knife to cut the sheets to fit my windows. Since my cuts weren't perfect, I taped the edges with black gaffer's tape. For the foam core I used, one side is white and the other is black. The black side faces in and the white side faces out. And since the windows are behind bamboo shades, you can't see the foamcore behind them from the outside. From outside, the white foamcore looks good.
You can buy this stuff at local photographer supply stores. You can't really buy it online (or at least I've never found it at reasonable prices).
"By my troth, I care not; a man can die but once; we owe God a death.... He that dies this year is quit for the next." -- William Shakespeare, Henry the Fourth, Part II
Rob Greer is offline
Reply Theater Room Items & Accessories
