Wall mount for small tv and directv receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-14-2013, 01:56 PM - Thread Starter
HowlinWolf's Avatar
So I have a small (I think it's a 22") LED tv in my weight room, with a Directv receiver. I really need to hang them both on the wall.
Is there a wall mount that will hold the tv, and also hold the directv receiver behind the tv (facing down)?
I don't really have the room in there to have the receiver facing out, so facing down would be best. And what better place for it than on the wall, directly behind the tv? That's about the best use of space I can think of in there.
Anyone know of a wall mount like this?
HowlinWolf is offline
post #2 of 8 Old 02-14-2013, 02:27 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
airscapes is offline
post #3 of 8 Old 02-15-2013, 08:12 AM - Thread Starter
HowlinWolf's Avatar
Thanks for the tips, but a shelf won't work for me. I need the receiver to be mounted on the wall, behind the tv. If it sticks out in that "shelf" orientation it will take up too much space.
I want to look at it and only see the tv, mounted to the wall.
post #4 of 8 Old 02-15-2013, 09:13 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Sounds like you will need to build that custom.. Wall mount the TV and velcro the box to the wall.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
post #5 of 8 Old 02-17-2013, 06:27 AM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
wall mount bracket for DirecTV receiver
http://www.solidsignal.com/pview.asp?mc=02&p=H25MOUNT&d=DIRECTV-H25MOUNT-Wall-Mounting-Bracket-for-the-H25-Residential--(H25MNT)&c=Satellite Accessories&sku=185463000641
underachiever extraordinaire
weaselfest is offline
post #6 of 8 Old 02-17-2013, 08:12 AM - Thread Starter
HowlinWolf's Avatar
Yeah that's pretty much what I'm looking for, except for the HR21.
post #7 of 8 Old 02-18-2013, 05:05 PM
HuskerDan's Avatar
If you have whole house dvr, I would suggest you get a different box for that tv. If you have the new Genie the satellite Genies will work perfect. Here are some pics of what I did, doing exactly what you want to do. I just bought a mount that has an arm to extend out. I then put the box on one of the arms and secured it and all the cables with zip ties. Works perfect.
HuskerDan is offline
post #8 of 8 Old 02-18-2013, 05:12 PM - Thread Starter
HowlinWolf's Avatar
Wow that is exactly what I'm trying to do. Changing receivers isn't an option though so I'll just have to look for a similar mount that is big enough for tyre HR21.
Reply Theater Room Items & Accessories
