Running DVI cable from HTPC to Projector help - AVS Forum | Home Theater Discussions And Reviews
Old 02-16-2013, 06:44 AM - Thread Starter
tcsekhar's Avatar
I need to run a DVI D dual link connection between my HTPC to my projector which are 30 feet apart and there is a 2" pipe to run wire. I won't be able to insert a DVI cable. Will running a HDMI v1.4 cable and using two HDMI female to DVI male connectors at the end work? Will there be any missing link due to convertions?
I was planning to avoid running CL2 D cable with wall plates for DVI and spend over $200 for this one. I would really appreciate your reply.
tcsekhar is offline
Old 02-16-2013, 04:18 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Yeah, you can do that.
Dropkick Murphy is offline
Old 02-16-2013, 11:23 PM
Colm's Avatar
Liked: 94
You can use a HDMI cable with HDMI/DVI adapters at each end, but it will be single link.
Colm is offline
