Newbie that needs some help with RF repeater system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-18-2013, 07:53 AM - Thread Starter
Johnnysbasebar's Avatar
I'm a newbie seeking some advice for my basement TV room.
My components will be in a closed cabinet in the same room, but not in line of sight of where we will sitting to watch TV.
I think I have to go RF vs, IR system because the cabinet door?
I'm planning on getting a Harmony 900 and this RF repeater. Am I missing anything? Does anyone have any preference or suggestions for a better way to go?
Logitech - Harmony 900 - 15 Device Universal Remote with RF -
http://www.bestbuy.com/site/Logitech---Harmony-900---15-Device-Universal-Remote-with-RF/9365395.p?id=1218091959397&skuId=9365395
Wireless Dual Band IR Remote Control Extender up to 328ft -
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=9194&seq=1&format=2
List of Components:
1. TV – Sharp - AQUOS - 70" Class (69-1/2" Diag.) - LED - 1080p - 120Hz - HDTV
2. Onkyo Receiver
3. Mirage 5.1 speakers & Polk Center(In wall)
4. Direct TV receiver
5. XBOX 360
Thanks for your help
Johnnysbasebar is offline
post #2 of 4 Old 02-18-2013, 12:15 PM
jautor's Avatar
Quoted: 1265 Post(s)
Liked: 813
Those two things don't go together... If you're spending money on an RF remote, you want the Hamony RF base station to go with it. The RF repeater system you linked to won't replace the Hamony base station - it's a standalone transmit/receive pair.
http://www.amazon.com/Logitech-Harmony%C2%AE-System-Harmony-Remote/dp/B008XTURU8/ref=sr_1_4?s=electronics&ie=UTF8&qid=1361218444&sr=1-4&keywords=harmony+rf
If the gear is just located in a cabinet - if you have a wire available or can add one, a simple wired IR repeater system would be the cheapest route:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=9895&seq=1&format=2
Jeff
jautor is online now
post #3 of 4 Old 02-18-2013, 03:44 PM - Thread Starter
Jeff,
Thanks for the help and I will go with the Harmony set up, that was exactly the help I was looking for.
Thanks again,
John
post #4 of 4 Old 02-18-2013, 09:59 PM
alittletank's Avatar
Liked: 26
I use the harmony 900 because my equipment is in another room. I highly recommend it.
Johnnysbasebar likes this.
alittletank is offline
Reply Theater Room Items & Accessories
