What would I need to do this.....? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-06-2013, 11:14 AM - Thread Starter
Tyrone Burton's Avatar
Hello people. Hope I put this question in the right place.
I'm basically trying to find options to route all my cables through one HDMI output. My cables consist of component and HDMI. I'd probably need this device to pass thru 3D too. I know there is the AVR option, but was wondering if there was any other option other than buying a receiver. Something that is dedicated to routing everything through one output.
Tyrone Burton is offline
post #2 of 8 Old 03-06-2013, 07:13 PM
BroncoSport's Avatar
A video processor like a DVDO I scan Duo will not only do that, but a whole lot more like up scaling all inputs to 1080p and with the right software and sensor it will calibrate your picture.
BroncoSport is offline
post #3 of 8 Old 03-06-2013, 09:41 PM - Thread Starter
I see. Thanks for the suggestions, but I'm also at the same time trying to keep input lag to a minimum for gaming. Those processors can add a bit of lag to the displays.
Is an AVR and video processor my only options for achieving this?
post #4 of 8 Old 03-07-2013, 10:33 AM
Josh Z's Avatar
Quoted: 2143 Post(s)
Liked: 1439
Most outboard video processors have a "Gaming" mode that will reduce lag by only doing a bare minimum of processing. However, that still seems like overkill for what you need.
Monoprice sells a number of HDMI switchers, some of which will pass 3D. They won't transcode analog component to HDMI though. You'll need a VP or receiver for that.
Do you not have a receiver at all now, or is it just that your receiver is older and won't pass 3D (or doesn't have HDMI)?
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #5 of 8 Old 03-07-2013, 10:49 AM - Thread Starter
No I have never had a Receiver before. If I am to get one it would be my first. It sounds like my best bet is an AV reciever, hopefully the one I'm looking at has a bypass mode (Sony STRDH 820), so no video processing goes on inside it. I'd let the PJ do that.
post #6 of 8 Old 03-07-2013, 12:48 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3042 Post(s)
Liked: 2976
Most AV recievers have pass through mode. Beside Sony, check out Denon.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #7 of 8 Old 03-07-2013, 02:10 PM
Josh Z's Avatar
Liked: 1439
Do you have a stereo or surround sound system that needs a receiver?
If not, your cheapest and easiest route would probably be to just buy an HDMI switcher and a separate Component Video switcher. That will reduce everything down to two inputs on your TV. Not perfect, but should be better.
Josh Z
Josh Z is offline
post #8 of 8 Old 03-07-2013, 03:49 PM - Thread Starter
I see, I'll check out some Denon receivers instead thanks.
Do you guys know if receivers will pass thru a 0-255 PC signal ok without bothering with it?
Reply Theater Room Items & Accessories
