Martin Logan Motion 15 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-20-2013, 08:15 PM - Thread Starter
BiGBryant's Avatar
Hello,
My name is Bryant, im looking to get mounts prefered the ceiling mounts for my Martin Logan Motion 15 speakers. They are book shelf speakers however here are the specs, the single thread on the back is 3/18-16 it's pretty big and uncommon. Also, the weight is 12 pounds and meassures wide 6.8" and Height 11.4"
Does Anyone know where i can get mounts for these speakers?
Please! Thank you!
-B
B
Denon Lover
BiGBryant is offline
post #2 of 11 Old 03-21-2013, 12:04 AM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
A search for "speaker mount 3/8" gives a lot of hits. Including Omni products:
http://www.amazon.com/OmniMount-Stainless-Steel-Speaker-Mount/dp/B00013BNLQ
BiGBryant likes this.
jautor is offline
post #3 of 11 Old 03-21-2013, 12:08 AM - Thread Starter
BiGBryant's Avatar
Hey thank you!
I did go to amazon spent about 3 hours looking. I ended up getting the omnimount 20.0c ceiling. It said that it fit that bolt. Martin logan speakers really are picky!
Thanks again!
B
Denon Lover
post #4 of 11 Old 04-02-2013, 01:19 AM - Thread Starter
BiGBryant's Avatar
OK!
The Omnimount's no longer make the once required! ! !
So here is the better choice actually!
These worked well i have the Motion 15 mounted!
Looks great!
The speaker brackets can be found on Amazon -
http://www.amazon.com/Vantage-Point-BSM-B-Bookshelf-Speaker/dp/B0000DIX1Y/ref=sr_1_12?ie=UTF8&qid=1363911821&sr=8-12&keywords=vantage+point+speaker+mount
The brand is Vantage Point (www.thinkvp.com) and the model is BSM-B, they are discounted on Amazon of course.
B
Denon Lover
post #5 of 11 Old 02-23-2014, 10:54 AM
Ben Hendrix's Avatar
Quoted: 24 Post(s)
Originally Posted by BiGBryant View Post
OK!
Looks great!
Can you post a picture of what this looks like?
also, how much can you angle the speakers horizontally?
Ben Hendrix is offline
post #6 of 11 Old 02-27-2014, 12:40 AM - Thread Starter
BiGBryant's Avatar
​As you can see the mounts are readily moveable and easy to adjust. I've had these mounts for a bit of 10 months and have not moved a centimeter off from where it was left. I love them, the metal posts and the threading to use the screws is amazingly strong. Keep in mind the mounts are METAL and they do have their own weight. So you have to add the weight of the mount plus the Speakers you choose to use and make sure you ceiling can handle it!
Overall no issues at all, i have 4 of these mounts holding 4 Motion 15's. The threading is so big it requires these mounts specifically!
​Hope this helps!
I fell that the angle Horizontally is about 180 degrees and vertically about 180 degrees. They are very customizable.
B
Denon Lover
post #7 of 11 Old 02-28-2014, 09:30 PM
Quoted: 24 Post(s)
As you can see the mounts are readily moveable and easy to adjust. I've had these mounts for a bit of 10 months and have not moved a centimeter off from where it was left. I love them, the metal posts and the threading to use the screws is amazingly strong. Keep in mind the mounts are METAL and they do have their own weight. So you have to add the weight of the mount plus the Speakers you choose to use and make sure you ceiling can handle it! [/SIZE]
​Hope this helps!
wow thank you so much for your great response and photos to go along w/ it. They greatly help and it looks like i'll be purchasing the same mounts this june when my house is completed and we can move in and set up 'the big system' biggrin.gif
post #8 of 11 Old 09-08-2014, 01:37 AM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
​Hope this helps!
Still liking these Vantage mounts? I'm thinking of using them for Motion 15's and Atmos overhead speakers. They will be about 3 to 4 feet from Main Listening Position, they should be able to point/angle towards the MLP, right?
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #9 of 11 Old 09-08-2014, 12:05 PM - Thread Starter
BiGBryant's Avatar
I'm loving these mounts, they are great have had them for a bit of a year and some change and they havent moved from the angle i've set them in.
Yes moving them and repositoining them is easy howevver i uge to have someone adjsut them for you as you it in the listening area. What i did was i had a guy come to install them we played music on just that speaker and meassured whether it was a good listening position and what may have you.
Great though! They are great!
Let me know if there is anyting else i can help with you.
post #10 of 11 Old 09-08-2014, 04:01 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
No other parts are needed for installation, correct? Just the speaker and the amazon mount?
Oh, maybe I need to buy 3/18-16 threaded bolts? How long did you use? From Home Depot or something?
SubSolar is offline
post #11 of 11 Old 09-10-2014, 06:20 PM - Thread Starter
BiGBryant's Avatar
Oh Sorry for the Late reply, I've been super busy!
Honestly i don't remember, however I'm sure the mounts bring the bolts. you might want to read on that or perhaps go to Vantage Point
website. Here is the link from amazon that has the mounts (They are cheaper now! lol)
HTML Code:
HTML Code:
https://www.thinkvp.com/products16-43/BookshelfSpeakerMountsPair
That one is for the original site.
I've attached the images from the site, According to what i found what the bolts do COME in the box, reminder ONE order is 2 Mounts. I did the mistake of ordering more than needed but I'm sure they can be handy in the future for a 9.1 lol
Again please let me know if there is anything else i can do to help!
ID:	256658   Click image for larger version
B
Denon Lover
Reply Theater Room Items & Accessories
