Rack for Large AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-05-2013, 03:57 PM - Thread Starter
TTUEagle's Avatar
Just bought this beast; Onkyo TX-NR5009. After Audyssey setup sounds fantastic with my Def Techs. However, I'm now faced with where to put this thing. With recommended space around the receiver, my old rack is obsolete.
Can anyone recommend a good open-style rack less than 30" tall with two or three shelves? Needs to house the receiver and have a center speaker sitting on top. I'd need to get two and set side by side to house the rest of the equip. Racks to be located on the floor, below a wall mounted flat screen.
TTUEagle is offline
post #2 of 2 Old 04-07-2013, 02:06 PM
dododge's Avatar
If you're okay with them being sloped backwards a bit, Middle Atlantic has some small and simple desktop racks that might work. They take standard shelves and accessories.
One catch with the angled rails is that if your equipment is really deep, you have to mount it higher up or it might touch the floor.
dododge is offline
Reply Theater Room Items & Accessories
