Rope lights - power cord WAY too long.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-12-2013, 02:43 PM - Thread Starter
dlambermont's Avatar
I bought some rope lights from Home Depot to go under the riser lip in my basement theater. They look great, except the power cord is about 5 feet too long, and ruins the look. I don't know much about these lights (Harbor Bay) - is there anything special about the power cord, or can I cut five feet out of it and splice it back together with black electrical tape? I did a search and found a number of threads discussing these lights, but nothing about hiding the LONG power cord....
dlambermont is offline
post #2 of 3 Old 04-12-2013, 03:50 PM
James Sponaugle's Avatar
Yes, you can certainly cut the length of the cord down. You just need to make sure that you don't rearrange the wires. . Keep track of which wire goes to which wire. If it's 120v AC (which is likely unless it has a wall-wart or other converter at the plug end), it actually won't matter how you reconnect it, but you'll want to keep it the same regardless.
James Sponaugle is offline
post #3 of 3 Old 04-12-2013, 05:20 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
A little safer way of doing this and a lot nicer looking than a splice, would be to cut 5 feet from the plug end and install a replacement plug.
macfan is offline
Reply Theater Room Items & Accessories
