Blu Ray/DVD Shelf - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-18-2013, 09:32 AM - Thread Starter
majek 60's Avatar
Quoted: 131 Post(s)
Liked: 121
Can someone tell me where to get shelves like this one?
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
majek 60 is offline
post #2 of 6 Old 04-18-2013, 10:54 AM
Selden Ball's Avatar
Quoted: 3427 Post(s)
Liked: 1698
They're called "floating shelves". A Web search for that topic turns up many sources and styles.
Selden
Selden Ball is offline
post #3 of 6 Old 04-18-2013, 11:16 AM - Thread Starter
majek 60's Avatar
Quoted: 131 Post(s)
Liked: 121
Looking for these specifically.
Did the search you have recommended and yes there are many versions, however I am looking for the ones in the pic.
majek 60 is offline
post #4 of 6 Old 04-18-2013, 11:51 AM
Liked: 1698
Sorry, can't help finding that specific model. I assume you're trying to match shelves which are already installed. They should have manufacturer and model on them somewhere, perhaps on the side that's against the wall. Have you tried contacting whoever installed them? They might still have the purchasing paperwork.
There are lots of very simple "black floating shelves", though. Adding transparent bookends would then hold the disc cases vertical and let you see the cover pictures of the ones on the ends.
Selden
post #5 of 6 Old 04-18-2013, 12:02 PM - Thread Starter
majek 60's Avatar
Quoted: 131 Post(s)
Liked: 121
I actually saved that pic from a thread here, liked what I saw, and can not find the thread to ask the poster where he/she got them.
I have searched the net with no luck, was hoping that someone here could easily point me in the right direction.
I could build them myself, however have enough on my plate these days.
majek 60 is offline
post #6 of 6 Old 04-18-2013, 12:57 PM
Liked: 1698
If you have a home-improvement store near you, like Home Depot or Lowes, you might consider browsing their shelves for something appropriate.
Selden
Reply Theater Room Items & Accessories
