Best screen for an epson 3010e projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-30-2013, 01:05 PM - Thread Starter
BillMar47's Avatar
I recently bought an Epson 3010e projector , have finished creating a dedicated room, and have reached the point of selecting a suitable screen. Did some research and have been looking in the $1000-$1500 range. One screen that caught my attention was the Lunette AcousticPro 4K series. Since the projector is known for its brightness, I was wondering whether to go with a cine white or grey screen material. Does anyone have this projector and could you offer me any suggestions on a good quality compatible screen?
BillMar47 is offline
post #2 of 2 Old 04-30-2013, 02:55 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
The standard approach is to contact the screen manufactures and request their free sample pack of fabrics. Then hang the samples and see what works best in your environment.. It isn't perfect but it give you and idea of screen texture, sparklies, and brightness from one fabric to the next. Every room is different and there is no one screen fits all. Also no way to test it and send it back if you don't like it.. Typically if your room is light controlled, which means No light source, Black or very dark walls, ceiling and floor, then some form of white screen is what you are looking for. Gray and high contrast are helpful to combat poor room design and high gain to compensate for low light output or attempting a larger screen then the projector can really light up properly with a utility gain. If you are going with AT screen then weave visibility, and audio interference are things to consider. A color neutral screen is what you look for no matter what the type if possible.
Here is a screen fabric report done by a forum member .. it is getting a little old but still can be helpful.
http://accucalhd.com/documents/accucal_front_projection_screen_report.pdf
Good luck!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Reply Theater Room Items & Accessories
