My poster box light is off :( - AVS Forum | Home Theater Discussions And Reviews
Old 05-03-2013, 01:10 PM - Thread Starter
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
I snagged an amazing deal on this poster box but we can't figure out what to do to get it to light up. We are nervous about opening it because it is sealed. Any ideas?.
megdagooch is offline
Old 05-03-2013, 02:36 PM
KenLerch's Avatar
If you haven't figured this out yet, it looks like the frame on the front opens up like a snap frame. Try prying each edge of the frame open with your fingers and pulling them toward the outer edge of the poster case. You can then remove the diffuser and overlay to get to the bulbs. Check the bulbs first. If it's not those, then it's likely that the only way you are going to get it working is to open up the box itself. It is probably sealed because it was used as an outdoor unit. So if you are not planning to use it outdoors then breaking the seal will probably won't matter. It it used fluorescent (which it looks like) bulbs it's probably just a bad ballast that can be purchased at your local Home Depot or electrical supply house for $15 or so.
Good luck!
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
Old 05-04-2013, 12:22 AM
warrenP's Avatar
Liked: 60
Inside, those are often just simple lights. As Ken mentioned, open it up and take a look inside. Best case, a simple bulb replacement. Worst case a few more parts to replace. You should be able to have that up and running in no time.
Every man dies. Not every man really lives.
warrenP is offline
Old 05-04-2013, 03:15 PM - Thread Starter
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
Thanks guys!!!! Ken your advise was a lifesaver!!! We have the lights and will be getting a price tonight. The ballast.....is not there! There isn't even room for one. We are wondering if its possible that it was external? [IMG][IMG][IMG]
Old 05-04-2013, 03:53 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
...The ballast.....is not there! There isn't even room for one. We are wondering if its possible that it was external?
Possible but highly unlikely. You probably have 2 ballasts (6 tube ballasts are pretty rare, 3 or 4 tube pretty common) and they are up in the top part of the box. Another option is to rewire the box to use these or similar: http://www.amazon.com/Ledwholesalers-LED-fluorescent-replacement-ballast/dp/B002P3FQI6.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 05-05-2013, 11:01 AM - Thread Starter
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
We have all the new bulbs. Not installed yet. While looking at where to put lights in I had a peek for the ballast up top. This pic shows a something?!? But unless it is a ballast, there is nothing up top. What you see here is the top thin frame, there is nothing above. The rest of it looks just like the bottom. No room for ballast. Well, I'm going to try the bulbs. Feel free to hit me with any more ideas. It's too simple to just replace bulbs. My confidence level for this working is low frown.gif keep your fingers crossed for me!
