Modding K-Mart Theater seats into loveseat. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-11-2013, 07:16 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
I have been working on transforming my K-mart theater seats into a loveseat configuration. IOOIOOI. It's a work in progress.
What you need is a piece of 1/2 to 1" thick (depends on how sturdy you want it) plywood or MDF. I used 3/4 MDF. Cut it 43-3/4" by 11". This will have the 2 frames of your seats bolted to it.
I took 2x4s and made a frame to go under the MDF. Just measure in a little over an inch on all sides and cut the 2x4s to those dimensions. (I think I cut 2 of them 41-3/4 and 2 pieces 6-1/8).Screw the MDF down to the 2x4 frame.
Now, line up the frame, taking care to make sure it's position correctly, and use the holes in the frame as a guide to drill your holes into the MDF. Get some 1/4 x 2-1/2 bolts. Use the new bolts and the original nuts to lock down the chair to the frame and the MDF.
bloodta is offline
post #2 of 6 Old 05-13-2013, 06:34 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
UPDATE...
I have finished one of the loveseats. Works very well. Here are some pics.
bloodta is offline
post #3 of 6 Old 05-14-2013, 07:36 AM
NickTheGreat's Avatar
Quoted: 410 Post(s)
Liked: 285
WOW. that's some good work. You wouldn't even know they weren't loveseats originally by looking. cool.gif
NickTheGreat is offline
post #4 of 6 Old 05-14-2013, 02:45 PM
Shawn Colton's Avatar
Can't find these chairs anywhere.
Shawn Colton is offline
post #5 of 6 Old 05-14-2013, 02:48 PM
JamesVG81's Avatar
Quoted: 61 Post(s)
Liked: 39
That looks really nice.. I really need one more of these seats.. I have 5 but really wanted 6..
JamesVG81 is offline
post #6 of 6 Old 05-25-2013, 03:16 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
Here is the dual loveseat configuration I made out of my K-mart theater chairs.
bloodta is offline
Reply Theater Room Items & Accessories
