DIY Star ceiling PANELS for drop ceiling. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 01-05-2014, 09:24 PM - Thread Starter
linkseo's Avatar
Liked: 25
Originally Posted by abovthurim View Post
Hey there - thanks for the post. I am about to take the economic route and do the same approach but had a question - what did you do with the grid face down after you installed the panels? Are they still exposed or did you spray paint them black to add a better blended feel with the black background of the LED kit?
i originally used black electrical tape to cover the grids. It gave off to much reflection though so ive since covered them with 1 inch black felt tape instead. now it pretty much all blends together nicely. can barely see the grids.
linkseo is offline
post #32 of 33 Old 01-06-2014, 06:08 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Question regarding this setup.. I was wondering If I used a sheet of insulation or if I built a frame out of wood and used Roxul safe and sound to stuff in there.. If I ran the strands of wire through the roxul would it be ok? I would need to do this because I would have acoustic panels in that spot.
Holiday121 is online now
post #33 of 33 Old 01-06-2014, 08:02 PM - Thread Starter
linkseo's Avatar
Liked: 25
I dont see why this would be a problem. The strands themselves dont give off heat from what i know. Only thing i would worry about is the illuminator box. It needs breathing room.
Not sure exactly what you mean about the putting the strands through the roxul though. I hope you dont mean running each strand one at a time.
I'd group the strands into one rope and make a hole in the roxul to put the rope through. After that, then you can branch out the strands.
linkseo is offline
Reply Theater Room Items & Accessories
