Corner wall mount for 60" plasma suggestions? - AVS Forum | Home Theater Discussions And Reviews
Old 05-18-2013, 07:52 AM - Thread Starter
cakem1x's Avatar
Hi all,
I recently bought a 60inch for the corner of my basement but I am having a hard time determining what wall mount I need. I want to the tv to extend far enough so it has enough clearance to reach a 45degree angle before the sides hit the wall. I can't find anything on the web that has a good rule or suggestion to achieve this. I am eyeing one that extends 25inches but I do not know if that will be enough. Any help would be appreciated!
cakem1x is offline
Old 05-18-2013, 08:07 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Have you looked at Monoprice.com
They have a lot of mounts and I have used 2 of the corner mounts for 42 and 47 inch led's. I am sure they have what you need to do the job.
Phil17108 is offline
Old 05-18-2013, 09:20 AM - Thread Starter
cakem1x's Avatar
It's not where to look. My concern is how far do I need the arm to extend out so I can angle a 60" plasma in the corner of my room. I'm hoping this one will work( http://www.amazon.com/gp/product/B0032QA93M/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1) and it extends out 25inches but is that far enough for a corner mounted tv that I want at an angle of at least 45 degrees?
cakem1x is offline
Old 05-18-2013, 06:27 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Don't know about the 45 degrees but the mount from Amazon will work for a conner. You can get just about the same thing from Monoprice for 40 bucks and there are planes, specs and costumer reviews right there to help you out. Find the stud that is nearest the corner, about 16 inches and use a yard stick to lay it out to see if you get what you want.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10828&cs_id=1082806&p_id=8586&seq=1&format=2
Old 05-18-2013, 09:52 PM - Thread Starter
cakem1x's Avatar
That's the same mount from amazon 26.5 inch extension. I still can't believe there isn't more information out there for this. TVs come in pretty standard sizes and so do mounts. Ugh
cakem1x is offline
Old 05-18-2013, 11:47 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
Draw it out showing the dimensions on a napkin (or other scrap paper) and use the Pythagorean theorem or other trig tricks to determine how long an extension you need. It's all just right triangles, after all.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 05-20-2013, 08:59 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
This. It really depends where you can mount the mount.
I did this very thing in my old place, but my set was smaller. It worked really well.
NickTheGreat is offline
Old 05-20-2013, 05:21 PM
scl23enn4m3's Avatar
It's literally the width of your TV divided by 2. No fancy math needed. Though I'd suggested framing out the angle with a couple of 2x4s and mounting your TV flat on that.
scl23enn4m3 is offline
