Remote Lighting and Control for a novice - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2013, 12:52 PM - Thread Starter
e485926's Avatar
Hello All-
I recently converted my Attic into a Home Theater. I have a 55 inch TV mounted and a 106 inch remote controlled screen for my projector. I have 2 cans of dimable lights which i have to manually turn off when i start a movie. I will be honest - i am not comfortable installing/changing lighting fixtures or switches. Thus keeping that in mind, do you know of products that i can use to remotely control the lighting? I was thinking the light (external fixtures or the 2 can lights) turn off when the movie starts and turn on when it finishes. I saw one product on Smarthomes that i think you plug into the wall - then connect a lamp to it. Is that the best product that i can find? Also, i was thinking of buying a harmony remote (as i have 3/4 remotes that i am using right now). Wanted that remote to be able to control the lights as well.
Any recommendation is appreciated.
e485926 is offline
