Does there exist a type of TV wall mount for a corner like this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-16-2013, 07:50 PM - Thread Starter
HarveySpecter's Avatar
I'm not sure how to refer to this specific type of corner, that goes outwards. Searching for "corner wall mounts" returns results for "normal" corners that go inwards, as I'm sure you'd imagine.
I'm looking to get a 65" TV, for what it's worth. And I'm quite certain there are aluminum studs behind the drywall.
HarveySpecter is offline
post #2 of 4 Old 06-17-2013, 06:49 AM
walterappleby's Avatar
Quoted: 26 Post(s)
Liked: 77
I would look at something with a swing out arm that you can mount to one of the sides of the corner.
Something similar to these should work I think: (I can't provide a recommendation for this or any other mount but show these here to represent the style of mount I think will meet your needs.)
http://www.amazon.com/Cheetah-Bracket-Articulating-Displays-Ethernet/dp/B009ZKXRLK/ref=sr_1_56?s=electronics&ie=UTF8&qid=1371476697&sr=1-56
http://www.amazon.com/Willies-Single-Articulating-Mount-Black/dp/B008J127VC/ref=sr_1_7?s=electronics&ie=UTF8&qid=1371476460&sr=1-7
walterappleby is offline
post #3 of 4 Old 06-17-2013, 07:00 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Your in a High Rise commercial building, check with the buildings facilities department before you try to mount anything on that spot.
Phil17108 is offline
post #4 of 4 Old 06-18-2013, 11:12 AM
Kalovaku's Avatar
Yeah make sure you check first. I would probably find another spot because I'm not sure if any mount would actually be secure right there. Can you keep it on a stand or mount it somewhere else, because that might be a lot better.
Kalovaku is offline
Reply Theater Room Items & Accessories
