Cup Holder for ordinary couch - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2013, 10:01 PM - Thread Starter
Marsupial's Avatar
Searching trough the forums only lead to older threads with dead links, but I am certain there are still people working out cup holders.
I am searching to do an addition to the otherwise "ordinary" seats I have for the theater room.
Unless I find anything better, I am thinking of going "arcade style"
http://www.pinballnews.com/learn/holder.html
Certainly there's something more appropriate that exist?
I am eager to hear about it.
-Mars
Marsupial is offline
Old 07-01-2013, 09:05 AM - Thread Starter
Marsupial's Avatar
nobody?
-Mars
Old 07-01-2013, 09:20 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Normally use a table when sitting at the couch .. tables next to chairs.. so if you want hand and table free maybe one of these?
http://www.google.com/search?q=beer+hat&tbm=isch&tbo=u&source=univ&sa=X&ei=EZ7RUeeTGLDJ0AH9uYDwDw&ved=0CFEQsAQ&biw=1024&bih=643
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Old 07-01-2013, 11:03 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
A "coffee table"?
jautor is online now
Old 07-01-2013, 05:12 PM
erichoya's Avatar
http://lmgtfy.com/?q=Couch+coozy#seen
Marsupial likes this.
Epson 5010 with 110" Accuscreen. Yamaha rx-v773, HTPC with XBMC.
erichoya is offline
Old 07-02-2013, 07:38 AM - Thread Starter
Marsupial's Avatar
that couchcoozy is a great idea. Thanks erichoya!
I was more thinking about something you could snap on the side of the couch somehow, some sort of chairside thin table or something.
I guess I'll have to rely on side tables.
-Mars
Old 07-02-2013, 08:30 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Old 07-02-2013, 10:49 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Get this or similar:
Cut a square into the armrest fabric/felt with the diagonal a little less than diameter of cupholder.
Pull out and away edges.
Cut out a circle underneath using a holesaw or similar.
Smoothen edges so they won't cut into fabric.
Slide in cupholder over fabric for that nice factory look.
You should do this if you can clearly feel hard surface below padding. Also it is a risky endeavor
as you could theoretically ruin the sofa. This would be a pink ban grade violation in my home.
Probably a home/auto upholsterer will also do you a good job on this project.
bobpaule is offline
Old 07-02-2013, 12:33 PM
Colm's Avatar
Liked: 94
I use an end table or coffee table. Maybe something like this would work for you:
Colm is offline
Old 07-03-2013, 07:45 AM - Thread Starter
Marsupial's Avatar
Seriously? The same useless joke twice in the same thread? Come on, you can do better.
-Mars
