Which surge protector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-15-2013, 10:44 AM - Thread Starter
nygiant75's Avatar
I'm going to be getting a new Panasonic ST60. I have a Directv receiver, Apple TV, will be getting a JBL sound bar and a blue ray player. I found this surge protector on Amazon which received great reviews. However, is it imperative to have a surge protector that allows coax cable and ethernet cable to also run through it? I was in Lowes yesterday and also saw this one. Any opinions on which one to get or should I be looking at something different?
http://www.amazon.com/gp/product/B0000511U7/ref=ox_sc_act_image_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
http://www.lowes.com/ProductDisplay?partNumber=131973-66906-UTHT8002&catalogId=10051&storeId=10151&langId=-1&productId=3158685
nygiant75 is offline
post #2 of 7 Old 07-15-2013, 11:10 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I have used Panamax for years, they can cost a bid more and what they call floor models have add on modules to expand the capabilities of them. Is your DirecTV a SWM or the older 2 wire one, thats how I got to Panamax in the first place they were the only one that had the 2 wire DirecTV system.
http://www.panamax.com/Products/index.php
Phil17108 is offline
post #3 of 7 Old 07-15-2013, 11:41 AM - Thread Starter
nygiant75's Avatar
Its the new Genie Directv. I guess it's the SWM?
post #4 of 7 Old 07-15-2013, 11:53 AM - Thread Starter
nygiant75's Avatar
I guess the main question is; do I NEED to run the coax and ethernet or just have all the sources plugged into it and leave it at that?
post #5 of 7 Old 07-15-2013, 12:02 PM - Thread Starter
nygiant75's Avatar
post #6 of 7 Old 07-15-2013, 11:30 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I use to run it all through the surge protector coax cat3 phone and cat5e, now I just plug everything into it and forget it.
The Tripp-lite should be all you ever need.
post #7 of 7 Old 07-16-2013, 10:26 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Older Panamax models with the analog backlit gauges (pre-outsourced days) for the prosumer.
Shunyata Research for the Class A monoblockistas.
I use two Panamax 5510 Pros with one in "isolated" mode for low current components, while the amps and sub get "balanced" power feed. This seggregation resufts in less EMI/RFI to the amps.
$15 3ft hospital grade cords are sufficient for me, after all I have no plans to change my house's standard 20A wiring anytime soon.
bobpaule is offline
Reply Theater Room Items & Accessories
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
