Need 10' tall and 45' long black curtain for less than $1MM. Ideas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-16-2013, 12:47 PM - Thread Starter
ahheck01's Avatar
I have a photography studio/giant theater room that makes up 2/3 of a 45' x 65' room. However, I need to separate that studio with the other third of the big room, thus I need a curtain that can be pulled across or pushed aside based on the need. It needs to be able to cover 45', and the ceiling height is 14' rafters etc. in the upper 3-4'. I have have a small curtain hanging down that top 4', then need a 10' tall curtain that can be pulled across. Doesn't need to be 1000% light-blocking, but 90% would be preferable.
I'm finding it nearly impossible to find - any suggestions?
ahheck01 is offline
post #2 of 3 Old 07-16-2013, 01:46 PM
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
I have looked for similar and ended up buying material at JoAnns and making it myself
megdagooch is offline
post #3 of 3 Old 07-16-2013, 02:38 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Have you looked at these sites?
http://www.showrags.com/
http://www.usedtheatricaldrapes.com/
http://www.sktheatricaldraperies.com/
http://www.solarisnetwork.com/stage_Theater%20Drapes
http://www.beckstudios.net/theater-curtains.aspx
http://www.mainstage.com/default.asp?id=61
Just google Used theater curtains for more..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Reply Theater Room Items & Accessories
