Component video cable question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-21-2013, 09:22 AM - Thread Starter
Ingeborgdot's Avatar
Quoted: 145 Post(s)
Liked: 27
I am in the need of component video cable and was wondering if monoprice component cable was a decent choice? It will be coming from a Canon XA10 into a Newtek tricaster. It will be sending video to the tricaster for our production broadcasts.
Ingeborgdot is offline
post #2 of 8 Old 07-21-2013, 09:54 AM
jautor's Avatar
Quoted: 1330 Post(s)
Liked: 852
I've used a bunch of the Monoprice component video cables without issue.
That said, for broadcast operations, I'd probably source a "better built" cable from Blue Jeans:
http://www.bluejeanscable.com/store/component/index.htm
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 8 Old 07-21-2013, 10:08 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 27
Then I look at the cables that come out of the camcorder and wonder if anything better than monoprice stuff needs to be used. ?????
http://www.bhphotovideo.com/c/product/749467-REG/Canon_4922B002_XA10_HD_Professional_Camcorder.html
look at the cables that come with the camcorder.
post #4 of 8 Old 07-21-2013, 11:00 AM
jautor's Avatar
Liked: 852
Stuff that comes "free" with equipment is certainly no better quality than what we can get from Monoprice.
My only concern is that cables that get moved around a bunch, or subjected to stresses by movement (like on a camera) and use, especially in professional environments, should have high quality construction. A/V cables meant for pro audio/video generally have more robust terminators, strain relief, etc. than the consumer AV-targeted stuff.
But if this is not "mission critical" stuff - any concern can also be alleviated by having some spare cables on-hand. The pricing on Monoprice gear makes that a no-brainer.
jautor is offline
post #5 of 8 Old 07-21-2013, 12:12 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 27
Yeah, and there is no alternative connection other than what they send, so I guess they must be good enough. You would think they would want the best possible picture they could get.
post #6 of 8 Old 07-21-2013, 12:38 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Why use the component connection? Can't you just play the video directly from the SD card and keep it in the digital domain?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #7 of 8 Old 07-21-2013, 12:56 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 27
No, it does not work that way with a tricaster. It is plugged directly into the tricaster to be able to use the virtual sets and multiple cameras option that the tricaster has.
post #8 of 8 Old 07-21-2013, 01:19 PM
jautor's Avatar
Liked: 852
Image quality is unlikely to be affected (on any short-length cable). It's the reliability / longevity of the cable that would be the only difference...
jautor is offline
Reply Theater Room Items & Accessories
Canon Xa10 Professional Camcorder With 64gb Internal Flash Memory And Full Manual Control
