mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-23-2013, 10:43 AM - Thread Starter
Dres1's Avatar
Hello,
I'm building my first home theater, and I plan to ceiling mount. I will be throwing from 14' away onto a 120" diagonal screen. Since I only have 87" from floor to ceiling, and I know that the offset of the projector is about 9", I was hoping someone could recomment a good ceiling mount. Basically I'm looking for the most flush ceiling mount I can get so that the projector is as close to the ceiling as possible. Thanks!
Dres1 is offline
post #2 of 2 Old 08-23-2013, 11:02 AM
walterappleby's Avatar
Quoted: 26 Post(s)
Liked: 77
Chief RSA is 1.4" + the mount plate. RPA is only 1.8" + the mount plate. With no downrod and bolted direct to the ceiling you lose the yaw adjustments without loosening your ceiling bolts, but once it's it place that isn't a big deal. Much closer to the ceiling and you will likely have ventilation problems anyway.
Chief makes some great mounts imo.
walterappleby is offline
Reply Theater Room Items & Accessories
