NEED a rack system for my cabinets!!! - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2013, 09:04 PM - Thread Starter
Ejs71's Avatar
Quoted: 38 Post(s)
Hi all.. I hope I'm in the right forum.
I've recently moved into a new home, and have a great surround set- up. I would like to keep my components in the cabinet to the right of the fireplace (that the tv is above), but I'm having a hard time finding a rack system to install. I really don't want to pile my components on top of each other and woudl like to use the left side of the right side cabinets. I plan on getting a power conditioner as well. So I will neeed to stack a receiver, BD player, DirecTv Genie, power conditioner (probably Panamax), and an Apple Tv which I can just put on the top of the BD.
Below is my situation. Can anyone help?!?!
There are 4 cabinet doors on either side of the fireplace/tv/ I am showing the right side only.
Panasonic 60GT50
Pioneer Elite SC-61
Oppo BDP-93
DirecTv Genie
Apple TV (3rd gen)
Monitor Audio GX50 bookshelf speakers (2)
Monitor Audio CT265-IDC in-ceiling speakers (2)
Monitor Audio GXW15 15" Subwoofer with 650W D2Audio Amplifier
Ejs71 is offline
Old 09-03-2013, 09:35 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
You'd need one of the Middle Atlantic slide-out cabinet racks - the sticker shock on those might change your mind. You really don't have a ton of equipment - using one or two of the pull-out bases might give you enough access without the expense of the rack and shelves. Remember that a rack requires rear-access so you can actually connect stuff - which is why the cabinet racks are pull-out and therefore not cheap.
http://www.middleatlantic.com/enclosure/main.htm
Your cabinet does appear to have good depth, which is a plus. I'd suggest an MA REB roll-out shelf to place the AVR on, which is the key piece that needs a lot of access. Stack the rest of the gear on the other side with the Genie on top so it has the best air circulation - nothing else in your list is a concern heat-wise.
http://www.middleatlantic.com/enclosure/roll/reb.htm
More important will be a cabinet cooling solution with both the AVR and the set-top box in there. Take a look at systems from Coolerguys, ActiveThermal or CoolComponents.
Jeff
jautor is offline
