Corner mounts for a tv - AVS Forum | Home Theater Discussions And Reviews
Old 09-07-2013, 08:58 AM - Thread Starter
uscuba2's Avatar
I am looking for a corner mount for a Samsung 50" Class 1080p 120Hz Smart LED HDTV UN50F6350AF. Any suggestions?
thanks
uscuba2 is offline
Old 09-07-2013, 09:59 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
thanks
Not sure what you are looking for exactly.. I had to buy one of these http://www.chiefmfg.com/Products/MWHVB so I could move my flat screen against the side wall for projection. If it was moved one stud closer to the corner it would be a corner mount.. Please note this thing is heavy, it weighs more than my Samsung and is over $300 but it made to move every day. Call the support department for assistance as they have a lot of similar models ..
See before and after photo below in my sig to see mount extended with 46" TV
Here are some other pictures of the mount as it was being installed and the room finished. http://misc.airscapesart.com/livingroom/index.html
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 09-08-2013, 08:08 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
olyteddy is offline
Old 09-09-2013, 09:10 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 258
I had a similar setup in our last place. Was like that for more than 5 years smile.gif
NickTheGreat is offline
