Using the Chief EVCM-100D Lift - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-21-2013, 02:20 PM - Thread Starter
FensterBos's Avatar
I purchased a home with a theater already in it with a Vidikron Vision One installed into the ceiling with a Chief EVCM-100D Lift. My experience with these things are kind of limited so I wanted to check with you guys real quick before I plug it in and try to lower the projector. I found some instructions for installing the lift on the web; it says that there are four clamps (Hasps), two on each side of the lift, that should be unlocked. I assume that these guys are used for precautionary matters so the weight of the projector doesn't wear out the lift. I just want to confirm with you guys that I need to unhook them before the lift can be lowered and I can get a better look at this projector - and by doing so the whole projector isn't going to come crashing down.
Thank you for your help!
FensterBos is offline
post #2 of 4 Old 09-21-2013, 03:14 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Can you give the original owner of the house and equipment a call? I would think someone who had such a high end setup would love to talk about it and would be happy to help you.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 4 Old 09-21-2013, 03:32 PM - Thread Starter
FensterBos's Avatar
I'm a little stubborn - I like to try to figure out how to do stuff. Of course, that is an oxymoron since I am reaching out to this board for help.
post #4 of 4 Old 09-29-2013, 05:34 AM
Tedd's Avatar
Quoted: 933 Post(s)
Liked: 345
http://downloads.chiefmfg.com/manuals-i/evcm100-i.pdf
and a snap from an old AVS thread that shows twin cables.
chief lift.JPG 95k .JPG file
Tedd is offline
Reply Theater Room Items & Accessories
