Need flexible blacklight to charge oval glow in dark ceiling mural - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-22-2013, 07:46 PM - Thread Starter
sfatula's Avatar
I have a semi large oval cove ceiling, with trim that would allow for recessed lighting around the oval. That lighting is intended to be blacklight to charge a ceiling mural of the night sky. The oval is about 20'9" by 13'5". So.... Tube lighting wouldn't seem to work since the oval is of course curved. Rope lighting would seem well suited, and I can find some blacklight rope, but, the questions would be:
1. Would the rope light be bright enough to charge to the center?
2. I have read from some mural painters that led blacklight is not proven to work yet to charge the paint. This is over a year old info, not sure if anything has changed. Also, what I have found is 405nm which I also read is not good for the paint, needs to be lower.
So, has anyone successfully used a flexible product that could be mounted in my oval cove ceiling to charge this large an area of paint? If so, where can I find it!? I would love to use led.
sfatula is offline
post #2 of 3 Old 02-24-2015, 08:43 PM
Metallus2000's Avatar
Liked: 30
Blacklight ropelight
Not sure if you're Still looking, but I found this online.
http://www.blacklight.com/items/UV5050300
Metallus2000 is offline
post #3 of 3 Old 02-25-2015, 12:03 AM
Th0r4z1n3's Avatar
Liked: 6
^I was going to point to almost the same thing, but quite a bit cheaper. These are a different model, but have twice as many LEDs: 5m roll of 3528 LEDs with 600 lights per roll
http://www.ebay.com/itm/5M-3528-SMD-...item3f3b73ba69
These are also the same thing: 5m roll of 5050 LEDs with 300 lights on the roll:
http://www.ebay.com/itm/5M-5050-SMD-...item4185bf3987
I'm not sure if they'll work exactly the way you want them to, but for $20 it can't hurt to give them a try.
Th0r4z1n3 is offline
Reply Theater Room Items & Accessories
