led recessed lights for Lutron MIR-600THW-WH 600-Watt Maestro IR Dimmer with Infrared Receiver - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2013, 11:15 PM - Thread Starter
sukumar's Avatar
Quoted: 12 Post(s)
I have installed Lutron MIR-600THW-WH 600-Watt Maestro IR Dimmer with Infrared Receiver switch long time back for controlling four recessed lights. The media room has hot spots near these lights. I was told it is due to non IC lights and there is no insulation.
What could be solution to replace these 4 lights but able to controller Lutron switch. Is it ok to change just LED bulbs or whole thing including can?
I am planning to add more insulation. While doing it, I want to put proper lights with insulation on top of it. Appreciate your help.
sukumar is offline
Old 09-30-2013, 07:39 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
There are plenty of dimmable LED bulbs out there.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 10-01-2013, 11:52 AM - Thread Starter
sukumar's Avatar
Quoted: 12 Post(s)
Thanks for the reply. I talked to Lutron long time back. I was told that the switch does not support dimmable. Not sure if things changed.
sukumar is offline
