Trouble with my popcorn machine. A spring isn't doing it's job. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-22-2013, 09:05 PM - Thread Starter
jeremytodd1's Avatar
So basically in the popcorn machine's kettle, there is a spring holding a piece down so that no popcorn kernals can get under it. I'm finding though that once popcorn starts popping some kernals make their way under that piece and stop the kettle's arm from spinning.
Upon inspection it looks like the spring is a little bit too loose so it doesn't hold down the metal part.
Is there a way to fix this?
Here is a picture.
jeremytodd1 is offline
post #2 of 2 Old 11-22-2013, 11:18 PM
Colm's Avatar
Liked: 94
Stretch the spring, shim the spring, or replace it.
Colm is offline
Reply Theater Room Items & Accessories
