Outer reclining seats with loveseat in between? - AVS Forum | Home Theater Discussions And Reviews
Old 12-10-2013, 11:23 PM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
I'm looking for something that has an outer reclining seat on each side with a loveseat in the middle. Researching furniture might be more difficult than the amount of time I researched a projector...is it best to just buy chairs with removable arm rests? I was hoping to find a wide loveseat in the middle instead of sandwiching two seats to make the loveseat. However, I'm not sure where I would find something like this or if it's even made.
|0|[ ]|0| ...so it's basically 3 pieces instead of 4. A curve would be nice too.
ch1sox is offline
Old 12-11-2013, 08:45 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
ch1sox,
Berkline used to have that extra wide seat you are talking about, but as you can see right now no one is offering something like that. It is not very popular, and the reason for that is the fact that for two adults it would be too narrow and uncomfortable, and for one the armrests would be spread out to far - again not that comfortable.
You will definitely be better off getting a loveseat configuration in the middle. Both seats will independently recliner, and the modular removable armrest makes this configuration very flexible allowing to convert the loveseat into two seats with the armrest in between.
Roman
rtheaters.com
Fusion Collection Seating
Ultimate Home Entertainment
rsh is offline
Old 12-11-2013, 12:15 PM
scraejtp's Avatar
Quoted: 40 Post(s)
I haven't seen a single seat love-seat recliner configuration. I have seen two chairs with a love-seat configuration (two separate recliners joined) from multiple vendors. (E.g http://www.amazon.com/Baxton-Studio-7-Piece-Leather-Recliner/dp/B000U9T6F6/ref=sr_1_13?ie=UTF8&qid=1386789038&sr=8-13&keywords=microfiber+recliner+sectional)
I think many sets can be easily modified to have the arm removed, even if it is not advertised as such. My Berkline set was supposed to be 3 chairs wide with armrests between each, but was very easy to change the configuration.
scraejtp is offline
Old 12-11-2013, 08:04 PM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 279
We have a set from Macy's that we love.
1603930_fpx.tif?$filterlrg$&wid=370
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
Old 01-05-2014, 09:54 PM
Smith82's Avatar
I just bought two single recliners and a loveseat recliner from Southern Motion. I have mine in a straight line, but you can add compartment wedges to curve them.
Dale
Smith82 is offline
Old 09-27-2015, 11:49 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Dale
How do you like the Southern Motion recliners? Are they power?
What model did you buy?
jimmyk36 is offline
