Any tv stands that hold albums? - AVS Forum | Home Theater Discussions And Reviews
Old 12-18-2013, 09:55 AM - Thread Starter
80sMetalForever's Avatar
Didn't find any in cursory search so I was wondering if anybody knew of tv stand 'furniture' that would not only hold components but also space for albums? I have about 100 and won't be expanding much beyond that so I was curious if those could be stored in the stand. I'm not looking to spend more than like $300-$400 so those high-end $$$ stands are out, if any exist. thx
80sMetalForever is offline
Old 12-18-2013, 05:46 PM
mjd420nova's Avatar
Check out he furniture dept at Target. They have a large number of sizes, styles and costs.
mjd420nova is offline
Old 01-21-2014, 09:57 AM - Thread Starter
looks like I could build something with Ikea
Old 01-22-2014, 12:33 PM
Krell789's Avatar
Hope this isn't to late before you go to Ikea. Go check out online www.Boltz.com they have products that might suit your needs, back in the late 90's I was in a similar situation I was looking for something that could hold my LDs and LPs. And deal with the weight, these shelves are made out of metal, they also have caster wheels so you can move them around the room very convenient, there in your price range a one shelf unit cost $289.00. One shelf can hold 180 LPs and 275 lbs. hope this helps.
Krell789 is offline
